cranking to nowhere...
Hey guys... I got a cranking problem... window not engine... I have a 89 dx hatchback and just a few minutes ago (literally) I was trying to lower my window on my driver side and the crank... well... it wasn't moving anymore... the crank did but the window is stuck at half way up... so... in short... HELP!!!
Bad window actuator. The actual actuating levers can slice your fingers off if your not careful but otherwise a pretty simple replacement. You can even find a replacement at your local junkyard
Morasso
Sep 10, 2009 05:31 AM
