Suspension & Brakes Theory, alignment, spring rates....
Camber Kit
Old May 13, 2009 | 02:58 PM
oahc's Avatar
Default Camber Kit
My 00 civic is lowered on 16 inch rims with tokico struts. The car is eating the insides of the tire like crazy. I just went to the shop and got some numbers, I have a -1.7 degree on driver side and -1.5 on the passenger. What kind and what brand of camber kit do you guys recommend?
Old May 13, 2009 | 03:06 PM
mugen si's Avatar
Default Re: Camber Kit
the main reason your wearing the insides of your tires is due to incorrect toe. dont waste you money w. a camber kit...the numbers you have listed for neg camber are not extreme. many run much more neg camber with minimum tire wear. just go back to your alignment shop and have them set your toe to either factory specs or 0 it out all around. good luck and this should do the trick.
Old May 13, 2009 | 03:27 PM
Tyson's Avatar
lol. 1.5 degrees of negative camber is NOTHING.
did you complete the alignment to fix your toe? how bad was that off...
Old May 13, 2009 | 03:39 PM
chargeR's Avatar
Haha oh dear -1.5 camber. As the others have said your tyres wore because your toe was messed up. Get it set to factory specs or zero by a decent alignment shop and don't buy stuff to fix problems you don't have.
Old May 13, 2009 | 06:36 PM
oahc's Avatar
o.O I see. I got the toe fixed up back to 0. But the mechanic told me to get a camber kit...Damn mechanic was trying to make some money off me. Also civics are front wheel drives so I only did the alignment on front wheels, assuming that I want to drop it more or get a different size rim, do I do some alignment on the back wheels too?
Old May 13, 2009 | 06:52 PM
verycleanhatch's Avatar
if you drop it more youll have to get another alignment. new wheels no need for alignment.
i would get a camber kit but it's not really required. for the rear u can just use washers.
Old May 13, 2009 | 07:16 PM
mugen si's Avatar
you always need to adjust the toe on the front and rear. if you lower the car more, you'll need to get another alignment. if you add different size wheels/tires you do not need an alignment, only when you mess with the suspension settings.
Old May 13, 2009 | 07:20 PM
oahc's Avatar
But doesn't the height of the car changes when you put in different size rims/tires on it?
Old May 13, 2009 | 08:09 PM
Tyson's Avatar
you need to get a 4 wheel alignment. even if its FWD.
ride height changes when you change tire size, in a way. but the distance from the axle to the fender, lets say, stays the same. so the suspension really isnt changing.
Old May 13, 2009 | 08:11 PM
Warhawk's Avatar
yes, but the geometry of the suspension does NOT change.
Think about it, with bigger wheels, the car sits higher, but the position of all the suspension parts remain in the exact same position, therefor you do not need an alignment from bigger wheels.
I'm glad that you realize that a camber kit is completely unnecessary! This has been a myth for quite some time. A lot of the newer cars come from the factory now with about the same camber you mentioned, and of course they do not have tire wear problems!
Old May 13, 2009 | 08:41 PM
oahc's Avatar
Oh...I see.
TonyRomo
Jul 20, 2009 01:24 PM
noz
Suspension & Brakes
Feb 18, 2009 07:53 PM
inspector01
Suspension & Brakes
13
Jun 27, 2008 04:12 PM
vdub08
Suspension & Brakes
19
Sep 3, 2005 01:14 PM
Ep3-4-EVA
Nov 15, 2003 05:10 PM
