how hard is it to replace the head gasket and what should i use?
Old Aug 18, 2002 | 07:31 AM
civicracer1993's Avatar
Default how hard is it to replace the head gasket and what should i use?
is it hard? should i use an actual gasket or the make a gasket silicon stuff?
Old Aug 18, 2002 | 02:35 PM
zcivic91's Avatar
Default Re: how hard is it to replace the head gasket and what should i use? (civicracer89)
yes u must use a headgasket..
Old Aug 18, 2002 | 07:05 PM
vtecrx's Avatar
Default Re: how hard is it to replace the head gasket and what should i use? (zcivic91)
sorry i'm not trying to sound like an *** but if you had to ask that question then i would really recommend that you dont try the headgasket without supervision. buy a helms or at least a chiltons and that will detail it.
Andy
Old Aug 18, 2002 | 10:56 PM
Aphrodavid's Avatar
Default Re: how hard is it to replace the head gasket and what should i use? (vtecrx)
agreed, have a professional do it. you WILL mess something up.
Old Aug 18, 2002 | 11:00 PM
NikoZai's Avatar
Default Re: how hard is it to replace the head gasket and what should i use? (Braveheart)
i'll handle this fella's
**** ITS HARD.
You would need:
Manual, really good one.
A good friend that will be there for many hours who has done a headgasket on their own, all by themselves and that may not fix it, a shop will have it tested to check for warpage, because if its warped, it wont seal even with a new gasket.
Old Aug 19, 2002 | 06:55 AM
BigDaddyRich's Avatar
Default Re: how hard is it to replace the head gasket and what should i use? (NikoZai)
Also Copper Head GAskets are pretty good.... worth the Xtra $$$ if you plan on boosting or heavy mods
Old Aug 19, 2002 | 07:21 AM
USDM 4G VTEC's Avatar
its not really hard but its complicated......
u need to use a gasket made for that specific engine.........
u CAN NOTTTTTTTTTT make a gasket made of silicon...... its not the thersmostat gasket. its the head one wich its criticall in the engine performance......
i have done a few head and engine rebuilds.....
and i tell u, since u dont know anything about it (since u asking "dumb" questions) just let someone else do it, and u can watch and learn,... dont try to do it urslef..... (nuttin personal, and dont wanna be an ***)
this procedure needs to be done carefully, so u get a tight seal, u get the right compression, u dont get any leaks, of water, oil or compression leak.. u gotta make sure the surfaces make a nice contact, the torque specs on the head that to be on a specific order and specific torque,,,,,,,,
get a manual from any auto part... read and learn and u qill see is not just take out and take in........ then u gotta look for piston rings leaks, since u take the head out u gotta check the cylinder walls to make sure they ok and yada yada yada.......
isnt that easy at all.......
Old Aug 19, 2002 | 08:04 AM
Steve91's Avatar
I would get the 92-up civic EX gasket. Its metal and much stronger. Drops right in.
Old Aug 19, 2002 | 09:09 AM
blacksoul's Avatar
A friend and i changed my headgasket in about 3 and a 1/2 hours, its pretty easy.
Old Aug 19, 2002 | 09:57 AM
slowwrex's Avatar
its not that hard to change the gasket. just follow directions. buy a new gasket and follow the torque seq in the manuel good luck
Old Aug 20, 2002 | 04:34 PM
ElectronMan's Avatar
Default Re: how hard is it to replace the head gasket and what should i use? (blacksoul)
Hey! I'm in Columbia and I should be changing my headgasket soon also. Any tips?
new_climber
Honda Civic (2001 - 2005)
Aug 28, 2023 12:11 PM
Poleke
Jun 20, 2019 01:49 AM
Randysi
11
Oct 24, 2011 07:39 PM
firstgenrex
Sep 24, 2003 08:37 AM
94gsr
Sep 12, 2002 11:37 AM
