accord misfire help
Working on a 1991 accord, f22 single cam. the car starts pretty much everytime, idles fine and revs up in nuetral just fine, as soo as you put it in gear, 1st or reverse, and try to let the clutch out the car sputters, misfires and almost always dies, the times it doesnt die, it will idle rough and misfire, upon normal shut off and start up idle will be fin with a random misfire here and there about every 5-7 second, there is no check engine light, ive tried the coil, ignightor, cap and rotor. i feel its got to be something in the ignition. when i first recieved the car there was a check engine light for the ckp sensor (crank position sensor) but after i jumped the code, removed the wire and started the car back up, the chek engine light was gone and hasnt been back since. im completely at a loss. any help is much appreciated. thanks in advance
And tram
Jul 21, 2013 07:09 PM
tcavazos
Jul 16, 2013 07:22 AM
Hondalina
Dec 13, 2010 02:39 PM
