89 CRX SI Running 5-7k RPMS on IDLE!! HELP
Old May 13, 2009 | 11:42 AM
hellraiser7492's Avatar
Icon6 89 CRX SI Running 5-7k RPMS on IDLE!! HELP
OH god. I just ordered a different throttle body because ours seemed jacked up, we replaced it and put it on and now it's running 5-7k rpms!
Before we replaced it, it was going from 2k-3k, rpms.
Can anyone assist with some information please?
Thanks!
[possible leaks?]
I'll take pictures if need be.
Old May 13, 2009 | 12:00 PM
innes887's Avatar
Default Re: 89 CRX SI Running 5-7k RPMS on IDLE!! HELP
did u tighten the throttle cable too much? any vacuum hoses disconnected? dashpot connected (if the new one has it) check engine light? did u bleed the cooling system?
Old May 13, 2009 | 12:03 PM
jlicrx's Avatar
sounds like you have a major vacuum leak
Old May 13, 2009 | 12:28 PM
digitally_remastered's Avatar
did you do a mpfi swap to this car? if so i wonder if you didnt reverse the tps sensor wires?
Old May 13, 2009 | 12:35 PM
sh!ft's Avatar
Who the fack changed my title?!
wouldnt make a difference....i just dropped in a z6 outta a 94 ex in my ef, and it barley makes the car throw the wtf code. try cleaning the t/b and the iacv/fitv valve. also take a look at the idle air screw.
Old May 13, 2009 | 12:41 PM
the throttle cable is fine, and the vacuum hoses are connected, and wtf is a dashpot? no check engine light and how do you bleed the cooling system?
Old May 13, 2009 | 12:50 PM
sh!ft's Avatar
look where the top hose going INTO the left side of the motor. theres a small screw that looks like a nipple. run the car while its just barley starting to warm up and the thermostat should open up and let water through. if you waste any coolant/water in the process, just fill'er back up
Old May 13, 2009 | 01:04 PM
innes887's Avatar
dashpot slows the idle from droping when letting off the gas or putting it in neutral. its on the front side of the intake manifold (furthest away from the firewall) and has a vacuum line going to it and a tab goin to the throttle body spring. if adjusted too high or not connected it will shoot the rpms up really high
Old May 13, 2009 | 01:25 PM
Yeah? How would I go about fixing that? [bold] FIX [/bold] excuse me, how would i find a leak and fixing it?
Old May 13, 2009 | 01:26 PM
I see, i'll go ask my girlfriends dad(he's the mechanic here) about it.
perhaps that's why but it could not be it because if it was like the last throttle body it'd only be throwing 2k-3k like before, maybe i just need to replace a gasket. i used silocone.. ONLY so maybe that's why?
Old May 13, 2009 | 01:29 PM
the thing is i can't even run it it pops up to 5k-7k rpms regardless and if i barely throw the acceleration cable it sticks and flys to redline and the only way to stop it is to turn off the car.
i might not understand what you mean about barely starting to warm up
Old May 13, 2009 | 02:21 PM
hellppp
Old May 13, 2009 | 02:33 PM
innes887's Avatar
well that would make sense if u sealed the tb w/ rtv. go buy a gasket and change it. my guess is that there are 2 problems. one was idling at 2k and the next was idling at 5k, so it seems like the gasket is leaking. fix that one then move to the next. theres really no way of texting it for a leak cus ur gonna blow ur motor before anything
Old May 13, 2009 | 02:36 PM
precisely, thanks!
Old May 14, 2009 | 01:25 PM
innes887's Avatar
no prob. let me know how it turns out
Old May 14, 2009 | 07:16 PM
the throttle body i bought was defective
Old May 14, 2009 | 09:38 PM
Fo-Do Fanatic's Avatar
so in the end it was fixed??? or was your dashpot just adjusted to high or the vacuume line off of it?
Old May 14, 2009 | 10:34 PM
the butterfly was warped.
hahaha
all it was]=
was leaking air because it was warped to ****]=
Old May 14, 2009 | 10:42 PM
thats dumb. where did you get your TB from? is it aftermarket or an OEM replacement?
Old May 15, 2009 | 07:49 AM
i bought it from a seller off ebay, he looked pretty clean but oh well.
he was nice otherwise and he offered a replacement but i'll just attempt to get my money back
just remember
always look at the butterfly.
lol
Old May 15, 2009 | 01:37 PM
just remember
lol
A lot of sellers on eBay won't give you your money back if they can replace it. Get his replacement and if that one is bad then attempt to get your money back. GL
SPIKE'S91CIVICSI
Apr 24, 2013 01:07 PM
freddy chavez
Apr 8, 2013 07:40 AM
SAfire
Jan 25, 2009 11:51 PM
adhawk76
Sep 30, 2008 08:08 PM
TheHatchHog
May 15, 2003 10:01 PM
