cooling system, is this normal?
Old May 13, 2009 | 11:08 AM
robbys89's Avatar
Default cooling system, is this normal?
hi all. iv noticed that after my engine(b16a) has cooled down the radiator hoses go flat due to some air issue, cause when i take the rad cap off the hoses spring back too there normal shape. iv bled the system many times and got new rad hoses. im not loosing coolant and i never over heat. any ideas or is it normal? just never noticed it with my other cars
Old May 13, 2009 | 11:09 AM
thi3v3z's Avatar
Default Re: cooling system, is this normal?
You should replace your radiator cap.
Old May 13, 2009 | 11:10 AM
Warhawk's Avatar
Sounds like it is not able to pull coolant out of the reservoir. Make sure nothing in that small hose or where it connects to the rad is clogged. Check the cap too
Old May 13, 2009 | 11:11 AM
thi3v3z's Avatar
Your radiator cap has a pressure membrane in it, and if its not working, it will allow pressure to build to high.
Old May 13, 2009 | 12:02 PM
robbys89's Avatar
okay ill try another rad cap and see how that goes. thanks for the imput lads
nevin
27
Mar 23, 2016 01:31 PM
snowblind7x
May 21, 2009 12:28 AM
lude98SH
Sep 29, 2008 09:24 PM
