98 JDM ITR distributor to 00 EX wiring harness?
Old May 13, 2009 | 09:57 AM
GetawayInMoscow's Avatar
Default 98 JDM ITR distributor to 00 EX wiring harness?
So I am doing my ITR swap in my EX and I noticed that the plugs on the dizzy are a bit different. It seems like on my B18C's dizzy the plug includes all the wires (10?) and on my stock wiring harness from my EX it's 8 + 2 in two plugs.
What do people usually do about this?
Old May 15, 2009 | 02:03 PM
94EG8's Avatar
Seagull Management
Default Re: 98 JDM ITR distributor to 00 EX wiring harness?
You can do a couple of things:
-Cut and splice (or depin) an OBD2A large distributor plug onto the civic harness.
-or swap the CYP/CKP/TDC sensors from the D16Y8 distributor into the ITR distributor case.
Be aware that the missing wire is for the tach signal, you don't need it if you are using an OBD2B ECU (these vehicles get their tach signal from the ECU instead of the distributor.)
Old May 19, 2009 | 10:23 AM
Katman's Avatar
To add what 94EG8 mentioned, if you depin your EX plug, here's a wiring diagram of how to pin the B18C dizzy plugs to your EX harness:
Old May 21, 2009 | 10:33 AM
hondaZvic's Avatar
katman,
im sure thats an old one, but u never cease to amaze me with your diagrams/ charts.
Old May 21, 2009 | 11:47 AM
Katman's Avatar
Originally Posted by hondaZvic
katman,
actually it's fairly new...whipped that up about a month ago or so.
Thanks for the props
Old Jun 23, 2009 | 02:13 PM
egb20v's Avatar
Are all the 96-98 ex harnesses this way
Old Jun 24, 2009 | 03:07 PM
Katman's Avatar
what do you mean? equipped with VTEC/KS/and primary 02 only ? if so, yes...
NathanMorris
Jun 8, 2007 08:00 AM
WuRKD b16
May 20, 2004 11:15 AM
