Suspension & Brakes Theory, alignment, spring rates....
Matching masters with brake caliper size/rotor.
Old May 12, 2009 | 08:17 PM
Jdmsoles's Avatar
From: Dodgin Cops all Round Ana-Crime to Orange & Sd
Default Matching masters with brake caliper size/rotor.
hey guys im interested in running a floor set up, but am wondering how do i go about matching my master according to my brake calipers and what else is involved in doing this, im running a tilton 600 set up, but dont want to buy the wrong stuff, and also goes with the clutch?? do i run my 5/8 that i have right now..?
car is eg with gsr rear brakes, stock front with a 15/16 master thanks a lot in advance.
Old May 13, 2009 | 10:11 PM
Jdmsoles's Avatar
Default Re: Matching masters with brake caliper size/rotor.
anyone??? serious this is the brake section and no one can help???
Old May 15, 2009 | 02:58 PM
FerreiraCompetitions's Avatar
Give me the specs on your front and rear brake setup. Disk diameter, disk swept area and caliper piston size. And also, what are you inteding to do with the car? Do you have an idea of what brake bias you want to start with? Let me know also what size and compound tires, any down force, race weight, is it a high or low compression engine. All of these things need to be considered when setting the brake bias.
Old May 17, 2009 | 09:04 PM
Jdmsoles's Avatar
. i found the formula, and it doesnt ask anything about disc size... and such just piston size sq inches of it to match with it...uh
I AM WEASEL
Feb 4, 2008 09:19 PM
BrakeExpert
Acura TL, RL & ZDX
May 25, 2007 08:29 PM
Lip
Oct 7, 2003 04:44 AM
