ECU will not turn on.....Help
Old May 12, 2009 | 05:59 PM
EF9Lowlife's Avatar
Default ECU will not turn on.....Help
I finished my minime(D16y8 on my d15b1 block) converted to multipoint too.(still obdo) Everything went well n Ef strted right up n drove for two dys.. so third dy i descide to cleen up engine by n by covering wires with blck E tpe......DONE......i go to strt my cr n no sprk...checked ecu n the led does not come on..then i tryed two other ecu's mines n 2nd pr3 n pr4...n nothing....my fuel pump comes on...so the rely is still good n it clicks. pleese help me out.......Thnks.
Btw i cn spell....sorry for writing weird, im missing letters on the keybord.
Old May 12, 2009 | 06:18 PM
allgo88's Avatar
Default Re: ECU will not turn on.....Help
check your fuses.
Old May 12, 2009 | 06:38 PM
EF9Lowlife's Avatar
^^ the fuses were good....under hood n in EF. checked
Old May 13, 2009 | 03:02 AM
EF9Lowlife's Avatar
nybody.
Old May 13, 2009 | 05:44 AM
dephtone's Avatar
I would replace the ECU fused under the hood just to be safe. I'v seen some fuses where they looked good but there was a tiny crack in it not making the full circuit. Either that or the ground on the thermostat housing needs cleaned as maybe it got corroded when you washed the engine bay?
Old May 13, 2009 | 06:19 AM
EF9Lowlife's Avatar
I will do....cn this coss the dissy to give no sprk to the plugs n not let the cr run......?
Old May 13, 2009 | 06:26 AM
EF9Lowlife's Avatar
heres the thing......vtec controller is hooked up to the pinouts of ecu power n ground......when i turn key to on pos. the vtec controller powers on but the ecu does not.....i disconected vtec n the ecu still does nothing....there for it wouldnt be ground becus the vtec controller is getting powered on......im lost i checked wired in engine by n cme up lost.
Old May 13, 2009 | 06:27 AM
EF9Lowlife's Avatar
replced fuses. nothing.
EF9Lowlife's Avatar
min rely clicks n fuel is being primed..
Old May 13, 2009 | 08:21 AM
sh!ft's Avatar
Who the fack changed my title?!
so the starter actually engages and spins the motor over but no spark from the dizzy?? and theres no flashing led at ANY point and time when you turn the key on?? check the fuses under the hood, and re-check your wiring(what ecu are you using??) and make sure you have no open connections or split wires that are grounding out and causing the dizzy/ecu to *** up
Old May 13, 2009 | 05:08 PM
EF9Lowlife's Avatar
when i tke out plug C the ecu led lights up n throws (code 16) when i go to put the plug C bck in the ecu does not blink.......this whole thing strted when i tighned up bolt to strter n rked it with the other side of rchet on pos term.....not on purpose tho......then this whole mess strted to hppen...before i rked pos. term. n strter. the Ef minime ws running no prb. Im using the PR3 ecu. Btw thks for helping everyone.
Old May 13, 2009 | 08:02 PM
EF9Lowlife's Avatar
my EF is mt.....why would it throw code 30.....wich hs to do with uto trnsmissions.?
H0NDASiR
Oct 8, 2010 09:36 PM
Ef2rollin
Dec 14, 2006 12:39 PM
drew2
Dec 3, 2005 11:51 AM
hybridb18
Apr 9, 2004 04:09 AM
