CRX trunk latch
Old May 12, 2009 | 05:51 PM
streetsold6teeny8's Avatar
Default CRX trunk latch
I cant f@(#in close the trunk on my crx... I know the locking mechanism sucks and almost all crxs do the same thing.... How can i fix this or what do you suggest.... i already used washers but it still doesnt close... also i played with the lathc and lock and nothing... any help appreciated
Old May 12, 2009 | 07:54 PM
KRock459's Avatar
Default Re: CRX trunk latch
can you manualy close the latch with a screw driver? If you can, it is an allignment or spacing issue. If it doesnt latch, try removing the rear access panel (reverse light cover) and you can see the mechanism. Make sure the exterior key release isnt binding, or the cable release isnt causing problems.
Kirk R
Old May 12, 2009 | 10:17 PM
nickhays13's Avatar
agreed. anyone else's latch make annoying noises when going over a bump in the road? mines rattles like a b**** every bump I hit.
Old May 12, 2009 | 11:44 PM
Ldo's Avatar
Ldo
I added weather strips around the trunk edge and used electrical tape to wrap around u-shape latch and that took care of my rattle and noise from the rear.
The dash and the doors, that's another nightmare!
Old May 13, 2009 | 09:59 AM
nickhays13's Avatar
So you put the weather strips around the edge where the plastic is, or where the trunk closes? I'm going to take a look at it today and see if i can fix the latch with electrical tape. Did you wrap it inside the latch? Or around it?
Old May 13, 2009 | 11:44 AM
crxsirg's Avatar
My latch doesn't close as well...but for mine it was broken. If you look at the locking piece, it's metal with a plastic tip. Well, that plastic tip just broke off after years of use. Check to see if that's your problem as well.
Old May 13, 2009 | 02:06 PM
nickhays13's Avatar
I have no problem with closing my hatch or the locking mechanism itself. Its just every time i go over a bump in the road or uneven surface it rattles. Its lowered
I'm thinking about wraping electrical tape around the U shaped metal piece located on the hatch that clips into the latch. That should cause less vibration and reduce the noise. hopefully.
Old May 13, 2009 | 03:11 PM
zrickety's Avatar
take it apart and wd40 everything. worse case, get a used one from the yard. my crx has 240,000 miles and i've never had a problem with the latch!
Old May 13, 2009 | 03:40 PM
ORANGE EF's Avatar
i had the very same issue a couple of days ago..... so i hopped in and kept trying to get it to work and finally i got so pissed off i hit it a few times with a bfh....
closes fine now
Old May 14, 2009 | 08:10 AM
SprintR's Avatar
lol thats called fixing it russian way
Old May 14, 2009 | 10:59 AM
Canadian_EF's Avatar
i can vouch for the electrical tape.
for some reason... it won't open with a key now. only the lever inside the car. wtf?
still rattles... but it is better than before. i think someone should make a DIY: Soundproofing the CRX.
Old May 18, 2009 | 04:37 PM
thanks guys hadnt been able to come on here for a while.. i sprayed lithium grease.. also yes it does lock with the screw driver which.. i adjusted it a little and it locked.. so thanks guys again
Old May 19, 2009 | 05:12 PM
BRAD@PASSWORD's Avatar
yeah both crx ive owned.. electrical tape worked...
91CTR
Mar 5, 2017 04:35 AM
B16CRXVTEC
Oct 14, 2010 08:35 AM
turbodrabbit
Mar 1, 2010 06:03 PM
rolledthatho
Sep 8, 2005 06:05 AM
c for sea
11
May 21, 2005 07:21 PM
