lights not working, need help
my cluter lights and tail lights are not coming on and when i replace the fuse it blows it right away. ground maybe? if so which one and where at? any other suggestions?
and my drivers side headlight isnt coming on either. when i bought the car it had a shitty wire tuck that went through the wheel well and it ****ed up all the wires, so i ran new wires. but all im getting is a turn signal light, but it blinks twice as fast as the passenger side. and when i compared the passenger to the driver, it doesnt look the same. when i wired it i wired it all correctly to how the housings matched and how they were when they were messed up, but i think at one of the connectors something is wired wrong. anyone have a picture of all that wiring in that area? any help is appreciated, thanks.
...and my drivers side headlight isnt coming on either.
...but all im getting is a turn signal light, but it blinks twice as fast as the passenger side.
[/quote]Check whether fuse 22 is blown or the bulb is blown.[/quote]
fuse and bulbs are ok.
[/quote]Check for a blown signal bulb or whether an incorrect signal bulb was installed.[/quote]
the bulb is ok. when i turn on the hazards it blinks at the right speed, but when i hit the turn signal thats when it blinks fast, and also shows the high beams blinking with it as well. like at the same speed, but i cant tell if the high beams are actually coming on due to the headlight being out.
You clearly have a short in the fuse 19 circuit, which also serves the taillights, front and rear parking lights, and the license plates lights. Carefully inspect each bulb socket and harness wires for damage and burning. The stereo and cigarette lighter are also on this circuit, so check there as well.
For the headlight, look for a bad bulb receptacle or a broken wire.
Blinker problem -- I think there's a problem with the G401 ground wire:
well does it connect in at the ecu? Because it kept burning into the wire harness way back, and i hate to have to pull everything out from the back of my dash to replace it, so if i can just by-pass it from the ecu to the fuse box it would save me a ton of hassle. or does it split off somewhere under the dash? and thanks again for the diagram
everything works now. only thing still not working is my driver side headlight. but my tail lights, cluster, heater/ac, stereo, cigarrette, etc... all those lights are working. what do i have to do with that wire now?
You cut the bad wire and fuse 19 stopped blowing, right? If so, something must not be working that gets power from a Red/Blk wire (see diagram). You need to find something on the fuse 19 circuit that doesn't work (due to cutting the bad wire).
everything except my clock and hazards now work. Like my clock is brighter when the lights arent on. when i turn the lights on it get real faint but its still on. honestly i cant find anything that isnt working. i checked everything then checked it again
The last step for the cut bad wire is to insulate the end attached to the rear of the fuse box with electrical tape so that no bare wire can cause another electrical short in the future.
The dimming of the clock light is normal.
yes i did cut it. thanks for all the help, I was practically pulling my hair out trying to figure out what was going on. I still need to get my turn signals on the drivers side to work properly. i looked for the box (G401) and if its mounted on the wall by the main harness then that seems to be fine. do you maybe have a diagram of the front headlight/signal wiring? i think its something there for some reason.
ok i checked the highbeams and nothing comes on, at least at the headlight, but it turns the turnsignal light on. it doesnt blink it just stays on solid. and when i hit the turn signal the highbeam indicator in the cluster blinks with it. so something between the high beams and turn signal are mixed up. everything on the right side works fine though.
yes. like i said i had to re-due that whole harness, so i just kinda of stuck that box to the car loosely. but now its grounded and the turn signal is the right speed and the high beams work, but no low beams still. also something i noticed is at g301 there are only 4 of the 6 plugs being used. but on the right side(G301 on passenger side), 5 of the 6 are being used. maybe the fifth is for the fan or horn though?
