Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
sunroof delete
Old May 12, 2009 | 03:23 PM
HFP_racing's Avatar
Default sunroof delete
whats the best way to delete my sunroof
Old May 12, 2009 | 03:50 PM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: sunroof delete
Can you give some more information? Is this a race car? Street/track car? What type of car at all?
Disregarding all those questions, the BEST way is to swap in a new sunroof-less roof panel. But that may not be legal for whatever class you're running in, if you're in a class at all. That's also potentially the most expensive and most intensive. So if money/time/effort is a factor, forget it.
Old May 12, 2009 | 04:27 PM
HFP_racing's Avatar
nah is my race car.right now no class at all but yea i was thinking of finding a integra rs an swaping it but to much money
Old May 12, 2009 | 04:43 PM
Suspetise...
Ok, then follow this link, and read away: https://honda-tech.com/search.php?searchid=1971079
FYI, I searched for "sunroof" and selected "Titles only" which limits the subjects to what are probably more pertinent threads, and then selected "Roadrace/Autox" forum, since that's the area that would cover roof plugs (as you know, since you posted here).
Old May 12, 2009 | 09:43 PM
HCivExoo's Avatar
that thread explains a DIY. There was a company making them i believe at www.lighterisfaster.com a CF roof Plug Kit around 400$ i believe they were for most popular Honda applications.
Old May 13, 2009 | 01:37 AM
SleeperGSR's Avatar
I tried to check out that website, couldnt get the link to work.
Old May 13, 2009 | 02:58 AM
Suspetise...
For reference, most sunroof plugs ARE DIY. There aren't many companies selling a kit. If you know of any others than what you listed (or the one you listed with a working website) that'd be helpful.
Edit: Here's the correct link: http://www.lighterfaster.com/4436/index.html
but I don't know how active/current it is. A phone call would be necessary, and the site does quote a $400 shipped price.
Old May 13, 2009 | 04:15 AM
Lo-Buck EF's Avatar
you can get just the center section of an rs roof skin. just some spot welds that hold it in. or you can buy a sunroof plug. i got one of those carbon ones, but you can make one from aluminum for ALOT less money.
Old May 13, 2009 | 06:36 AM
.:Made in OC:.'s Avatar
I am actually currently working on pre-cut sheet metal sunroof deletes with all hardware for Honda's. Sometimes people rather not spend $400 on carbon fiber. What car is this for?
Old May 13, 2009 | 06:40 AM
Lo-Buck EF's Avatar
seriously. once i installed the lighterfaster kit i realized how easily i could have made something up for way cheaper.
Old May 13, 2009 | 06:44 AM
red_crx's Avatar
Do you have any pics of yours?
Old May 13, 2009 | 08:42 AM
RagingAngel's Avatar
I found a lightly damaged (in the corners) Suzuki Aerio hood and had the bodyshop cut off the skeleton and they bonded it in place with glue and rivets. A couple of hours later and $30.00 bux paid, I had a sunroof plug for my 93 Si hatch.
Ain't the prettiest thing, but I'm happy for what it cost.
Old Jun 21, 2010 | 08:46 AM
MikeTheGreek's Avatar
What I did to mine was make a template of the sunroof went to the junkyard found a 1993 corolla placed the template on the roof cut it out with some metal sheers. Then I brought it back grind around the hole where my old sunroof used to sit then line up the metal panel that I cut with the hole hold it in place with weights or clamps then carefully tack weld it from the inside of the car spacing my welds about 1 foot apart until it was sealed. then to smooth things out up top i used metal filler around the seem then sanded then use lightweight filler then sanded again then I used body glaze to seal it followed by primer sealer. I also just tacked in 3 braces along in the inside to give it a little strength but I found later that I did not need to do this as the metal panel I used does not make any noise when I hit a bump nor does it move at all unless an acorn hits it damn squirrels! I am working on a custom headliner to fit now but it shaved a lot of weight and looks 100 % stock!! I will have to put some pictures up!
Old Jun 22, 2010 | 10:40 PM
civichb20's Avatar
PM Garage
I replace my sun roof for my CRX si with a DX it was not to hard all you need a spot weld remover bit and a welder it only cost me around $300 with install and roof. This would be a great time to do you roll cage gl. Oh yeah you have to remove the windows and hatch etc.
miamirice
102
May 14, 2013 01:55 PM
AMeg6
10
Sep 22, 2009 08:15 PM
Dave_B
Oct 14, 2008 02:15 PM
K.Gallagher
Honda Motorcycles
Jul 17, 2006 11:06 AM
