ebay window visor?
Old May 12, 2009 | 01:47 PM
bluestd's Avatar
Default ebay window visor?
hey i was wondering if the ebay ones are good was looking at a set for the hatch and it uses 3m double sided tape for installation u peel it and just stick it on while pressing it in place for 2 minutes is that right? i thought they use clips to install any feed backs will be appreciated
Old May 12, 2009 | 02:29 PM
4g4dcruisin's Avatar
Default Re: ebay window visor?
ebay uses the 3m tape. i've had mine on my sedan for like a month now and they work fine, havent came off!
the OEM ones use clips to secure onto the door.
so yea get the ebay ones....cant hurt
Old May 12, 2009 | 02:54 PM
jdm206's Avatar
My friend had some of the ebay visors on his ef sedan and one day when he was driving one of them flew off on the high way.
Old May 12, 2009 | 03:05 PM
that sucks for that dude....mine have been fine even in heavy winds.
Old May 12, 2009 | 03:14 PM
ALLxMOTOR EG's Avatar
Vietnamese!
OEM ones cost more but well worth it in the long run, can't go wrong with OEM.
Old May 12, 2009 | 03:16 PM
black0hatch's Avatar
i got them on my 4 door and one of the rear ones is starting to come off it flaps in the wind but the other 3 are on solid i preped mine really good too i scuffed the door up and cleaned it really good.
Old May 12, 2009 | 03:17 PM
sh!ft's Avatar
Who the fack changed my title?!
wow it just dawned on me, get the double sided clips and use egay visors!! O_O i just had an idea!!!
Old May 12, 2009 | 03:19 PM
the only differences ive noticed between my ebay ones and the OEM....the ebays are a lil longer and they are darker than the OEMs.
the oems have like a brownish tint, the ebays are "limo" tint.
Old May 12, 2009 | 03:30 PM
clovis88crx's Avatar
not sure about ef hatch, but the oem honda access crx ones uses double sided tape and 4 clips that just snap on.
Old May 12, 2009 | 08:22 PM
uberEFtuner's Avatar
Free 3m tape lesson:
#1 clean off the surface
#2 Use a heat gut to warm up the tape( or use a lighter)
#3 Push hard for a 10 seconds
Old May 12, 2009 | 08:32 PM
EJ1_Sleeper's Avatar
if you dont have the door mounted belts check out www.weathertech.com
ive got them and lovem. no they dont come in a dark tint, but i prefer it that way since i have no tint. no tape no clips. slides in and stays VERY well. had them on 2 cars so far.
Old May 12, 2009 | 08:41 PM
cloviskilla's Avatar
i bought a 3m stick on window visors off ebay and they didnt fit worth a **** pieces of **** i threw them away.
Old May 12, 2009 | 08:57 PM
NlCK B's Avatar
those weathertech ones look pretty good might pick up a pair
http://www.weathertech.com/store/mvp...ptChoiceIds=59
Old May 13, 2009 | 08:27 AM
sh!ft's Avatar
meh i can barley see them, if they were in MABEY a tab bit shade darker, then i would consider buying a set...
Old May 13, 2009 | 10:40 AM
mitsubishiv5's Avatar
wtf happened to reply i added? stop reposting the same **** every single day and use the search function!
Old May 13, 2009 | 10:59 AM
crx_si-r's Avatar
hey mitsubishiv5 I know you used to have oem Crx visors, how do the clips install? I ordered oem ones for my Crx.
Old May 13, 2009 | 12:06 PM
My_EFsedan's Avatar
i had my ebay visors for 3 years now, from time to time i tend to get to 100mph. at one point at 140mph, the visor is holding up great.
dont assume that 3m tape visor are bad. if your **** falls off, your doing something wrong.
this works
#1 clean off the surface< REALLY CLEAN
#2 Use a heat gut to warm up the tape( or use a lighter)< perfer heat gun because you can heat the majority of the tape faster so one side doesnt get cold while heating the other one.
#3 Push hard for a 10 seconds< after being pressed down, i use clamps to clamp the visor down to the door
Old May 13, 2009 | 12:07 PM
hey our cars are twins just so u know. except for the deepdish wheels and black hood.
Old May 13, 2009 | 12:12 PM
My_EFsedan's Avatar
good for you.
Old May 13, 2009 | 12:13 PM
well i never said it was intentional or really a good thing. but yea people compare mine to yours, JUST THOUGHT I'DE SAY SOMETHING TO YOU ABOUT IT.
Old May 13, 2009 | 12:17 PM
My_EFsedan's Avatar
EDIT: back on top.
"dana bandwagon" what a joke. FYI my hood/trunk/roof is back to gray. go compare to me more.
Old May 13, 2009 | 12:23 PM
EDIT: back on top.
yay can i really?thank you so much!
Old May 13, 2009 | 12:24 PM
My_EFsedan's Avatar
yea, go ahead. brag away.
Old May 13, 2009 | 12:25 PM
i'll be at the next meet by the way
Old May 13, 2009 | 12:27 PM
My_EFsedan's Avatar
good for you.
riceforlife
Lighting
10
Dec 23, 2007 02:36 PM
H23vtecEG
Jun 21, 2005 06:05 AM
bonta-kun
Jul 25, 2004 10:13 AM
Discosteak
Jan 1, 2004 03:26 PM
