Will a 1995 EX Cluster fit my 1996 EX?
Hello. I found a 1995 Honda Accord EX Inst.
Cluster with auto trans., with ABS.
Will this fit my 1996 Honda Accord EX, auto, four door with ABS?
Does it matter that the 1995 was a two door?
Thanks in Advance.....
They will fit. Only difference is the 4 door has the little car with 4 doors. 2 door with 2 doors. So if you open the back doors, the dash will not display this. You could take them apart and swap the parts. Why are you doing this if you have EX and cluster is from EX?
Thanks for the confirmation. My speedo goes crazy now and then and I have to use the rpm for my speed. Wanted to change out the whole cluster and keep the old cluster for spare parts for the guages that work. The one I found only has 79k so hopefully it will be problem free for the life of the car.
