LS Swappped CRX Questions, Mounts, AC ?HELP?
I purchased a 90 CRX SI with LS Swap and sometimes I believe I am in a bass cannon. What are the least, "shake your ***** loose" factory style motor mounts I can install to cut down on the "Hasport Shuffle" that I am experiencing now? I also want to reinstall the AC but dont know if it will work in the swap?? I am currently looking for the LS ac parts. Also does anyone have the link to the LS CRX Swap page?
B18A1
YS1 Cable Trany
Thanks
B18A1
YS1 Cable Trany
Thanks
why not just use civic ac parts? unless it's just for 92-00 you can get the ac bracket for a del sol vtec or a crv for the ac and call it good. some one verify this for me plz tho
id personally just use the same a/c parts and use the ls bracket. or use a/c compressor/bracket from ls and use original lines since they are basically in the same position/location
if you have the sanden compressor and original crx a/c parts, an innovative a/c bracket is your best bet. you may also need an aftermarket front crossmember or modify your existing one.
your only other option might be a combination of ls and crx a/c parts. i'm assuming the car still has the a/c button and evaporator. what parts do you already have?
First of all I appreciate the help and wanted to say thanks.
I have the stock crx Condenser, Drier, AC button, Lines. I need a compressor, idler pulley/adjuster?, compressor bracket.
Thanks
Thanks
averyvm
May 27, 2008 10:10 AM
tRex99
Sep 16, 2004 08:12 PM
