..::: HELP! Car won't start :::..
Old May 12, 2009 | 07:17 AM
LOVEthatDC2's Avatar
Default ..::: HELP! Car won't start :::..
Went out last night to start the car and all I hear is a single CLICK when I turn the key ...
All the lights worked and didn't dim too bad but I decided to jump it anyway and give that a try ... nothing.
I'm thinking the starter went out, can anyone confirm? Thanks
Old May 12, 2009 | 09:03 AM
Berlinetta F1's Avatar
Default Re: ..::: HELP! Car won't start :::..
check the starters power conections
check the starters fuse
if both of those are good and you still get nothing try hitting the sarter with a blunt object and then try to start the car. it sounds silly I know, but it has worked for me quite a few times.
if you try hitting it and it works your starter is on its way out and will need to be replaced.
Old May 13, 2009 | 08:19 AM
buddy of mine had a replacement starter so I swapped it out really quick, turned out to be the starter
another fun thing was trying to figure out how to kill the alarm haha
Tunerguy1989
Nov 16, 2009 03:52 PM
IntegraPir4te
Mar 19, 2007 10:51 AM
da6er
Jul 8, 2006 02:36 PM
nomotorsol
Feb 20, 2005 12:02 AM
