HELP I'm doing an obd1 swap in an obd2 automatic car ....
Old May 11, 2009 | 11:08 PM
screen_name's Avatar
Icon2 HELP I'm doing an obd1 swap in an obd2 automatic car ....
anyways, my question is... all the obd2 to obd1 jumper harnesses i can find are for manual transmissions only... the only automatic one i have found is rywire for $250 http://rywire.com/store/automatic-ob...9537364f2a8ad7 which is a little out of my budget for a jumper harness, anywho is there a way to flash and obd1 ecu to not read the automatic transmission sensors so it will let me shift from park to drive?
Old May 12, 2009 | 08:22 AM
Default Re: HELP I'm doing an obd1 swap in an obd2 automatic car ....
upp
Old May 13, 2009 | 07:17 AM
ttt
Old May 13, 2009 | 02:00 PM
94EG8's Avatar
Seagull Management
What engine and tranny do you have in what car?
Old May 14, 2009 | 09:50 AM
obd1 d15b with obd2 auto tranny in a 96 civic dx
Old May 14, 2009 | 05:06 PM
94EG8's Avatar
Seagull Management
You'll have to run an OBD2A P2P ECU (assuming you're refering to the JDM D15B Vtec) If its non vtec run a P2E. You can't run an OBD1 ECU, period, getting the tranny out of park isn't really a big deal, but it wont shift right with an OBD1 ECU.
Just thought i'd add, your timing is probably going to be a little off, theres not really a whole lot you can do about it. just hope its close enough that it works alright.
Old May 14, 2009 | 05:25 PM
jdm inc's Avatar
mariog96teg
Dec 12, 2013 10:03 PM
screen_name
Engine Management and Tuning
Jun 11, 2010 11:47 PM
SOHC_MShue
Jun 13, 2007 07:39 AM
zacknj
Oct 13, 2005 05:43 PM
Mr.DC2TurBo
Oct 17, 2003 09:57 PM
