missing bolts
Old May 11, 2009 | 10:24 PM
tempsohc's Avatar
Default missing bolts
Hey i was wondering if there was any alternative to acura/honda oem bolts because im missing quite alot of bolt which includeds the 16 bolts for the transmission 3 bolts for the intermediate shaft and misc bolts for motor mounts brackets which equaled up to 84 dollars from acura by the way this is for a ls motor if your wondering. and like i said is there some place cheaper yet with the same or better quality as oem that wont ruin the block?any one running them? lmk
Old May 12, 2009 | 06:23 PM
hailchristian's Avatar
Default Re: missing bolts
Im running a few bolts i picked up at a local hardware store.
I use this site at work a lot, can probably find most of the bolts for a lot less as long as you know the specs on them..
http://www.mcmaster.com
Old May 12, 2009 | 06:27 PM
black0hatch's Avatar
hit up a junk yard. the 3 for the half shaft are special bolts you cant just use a regular bolt. youll know if you see them. theres a bigger shaft on the bolt that centers it. i like to use oem bolts cause they have that little washer thing on the head.
Old May 12, 2009 | 06:31 PM
EJ1_Sleeper's Avatar
what he said. best bet. shopping spree at the junkyard man, you can EASILY find all those bolts. Its exactly what i did, I still need to go and get the rest of the crap im missing.
Old May 12, 2009 | 06:47 PM
luis84one's Avatar
junkyard!!!!! and take big pockets!!!!
Old May 12, 2009 | 11:29 PM
tempsohc's Avatar
haha alright ill try hit up the junkyard sometime soon thanks alot but if there isnt any how safe would it be to use the bolts from that mcmaster site for the driver side motor mount and the rear trans mount btw i just found the three intermediate shaft bolts thanks for the input keep it coming
Old May 14, 2009 | 01:07 AM
tempsohc's Avatar
can anyone give me the parts numbers for the trans to bolcks bolts cant seem to find the correct one? and how many are needed?also are the d series ones the same as b series?
Old May 14, 2009 | 01:08 AM
tempsohc's Avatar
any of these???
http://www.acuraoemparts.com/delray/...All&vinsrch=no
20CiviC02Si
Mar 30, 2015 08:03 PM
JJGL-EF90
Oct 8, 2010 01:27 PM
Kongo69
Honda Civic (2001 - 2005)
Jul 5, 2008 02:51 PM
HondamanXxX
16
Jun 29, 2007 04:17 PM
