Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
coil over problem
Old May 11, 2009 | 07:19 PM
lowlife9's Avatar
Default coil over problem
i just received my progress coil overs from corsport on the box it said 01-03 i drive a 04 and i ordered these specifically for my 04 and i remembered hearing that the 04 needs 16 mm bolts so when i try to attach my camber bolts they did not fit so what now could they be the wrong camber bolts if they did fit look how much the bolt sticks out the end.
Old May 11, 2009 | 07:30 PM
toyomatt84's Avatar
Sanji
Default Re: coil over problem
Get a 5/8" drill bit, and drill out the holes on your coilovers. The bolts are supposed to sit like the top bolt is lined up.
Old May 11, 2009 | 07:42 PM
lowlife9's Avatar
i just found out they sent me camber bolts for 04-04 SI will that not make it fit and why should i have to drill doesn't progress make them specifically for 04 .
Old May 11, 2009 | 07:46 PM
metalviper's Avatar
you have the right cam bolts but you should have order the coilover set for the ep3. i inquired progress about this a while back and they are EXACTLY the same EXCEPT the 75.1007 (the ep3 kit) has the larger holes in the clevis bracket to use with the 16mm bolt and knuckle
Old May 11, 2009 | 07:49 PM
toyomatt84's Avatar
Sanji
Your coilovers have the wrong size holes for the bolts. They sent you the wrong model (you have the 14mm bolt model, when you need the 16mm bolt model).
Old May 11, 2009 | 08:24 PM
lowlife9's Avatar
what obout the camber bolts the 04-05 si and 04-05 dx are the same why do they have different part numbers??
Old May 11, 2009 | 09:48 PM
metalviper's Avatar
they use the same cam bolt
Old May 12, 2009 | 05:02 AM
homelessEm2's Avatar
drill that hole on the top out and call it a day. all the whining and bickering you did in this pointless thread, you could have had these on already.
Old May 12, 2009 | 12:13 PM
Curiouz_G's Avatar
this
Old May 13, 2009 | 02:11 PM
lowlife9's Avatar
what about the bottom don't i have to drill that out to???
zzzzzsi
Aug 28, 2006 07:10 PM
JamesQ
Dec 15, 2003 08:17 PM
Fuster_Cluck
17
May 17, 2002 10:43 AM
fcuked
10
May 8, 2002 09:18 PM
Fuster_Cluck
Apr 14, 2002 11:37 AM
