90 ef wont stop 2 stepping
Who the fack changed my title?!
like the title says, it wont stop 2 stepping when i press it wot and at idle i try to take off the car dies untill i let back off the gas....and i think the idle is messed up cause i have to litterally(with my foot) pull the pedal back towards me to get the idle back down
ps-car is swapped with d16z6 and converted obd0 to obd1 p28.
Is it throwind a check engine?
Sounds like the car might be in limp mode OR if it does have a chipped p28 in it with a launch control feature it is not sensing a vehicle speed and hence not getting out of the FTL routine.
ok now(for some odd reason) the car is throwing codes 1,5,6,7, and 8...but i fixed the dying, i can actually put the car pedal to metal and it rev. but i let off and it stays at 4k untill i pull the pedal back with my foot and then it goes back to erratic idle from 1k to 1.25k
any ideas??
any ideas??
but now my question is, the fitv valve, is the inside screw supposed to be screwed all the way tight or turned tight then turned back out a quarter??
http://www.team-integra.net/sections...ArticleID=1167
either where it was before if it idled good or adjust from there.
sounds like you need to do a few things:
1.) make sure u have no vac leaks
2.) clean icav
3.) clean and readjust fitv (done)
4.) completely bleed the coolant system
5.) maybe readjust your throttle cable tension
2.) clean icav
cxvtec
Oct 27, 2006 06:22 AM
