lots of movement on drivers front rotor
Old May 11, 2009 | 06:33 PM
googoodc's Avatar
Default lots of movement on drivers front rotor
ok i have a 1994 ls. i noticed about a month ago that when i go over bumps in the road i heard metal on metal clanking and after a week it got gradualy worse. so i jacked the car up and took my wheel off and realized that my rotor moves way to much. i checked my brake caliper to see if it was loose but it wasn't . i realy have no idea what the hell is up so if you guys have any idea i would love your input.
Old May 11, 2009 | 06:54 PM
googoodc's Avatar
Default Re: lots of movement on drivers front rotor
anyone
Old May 12, 2009 | 09:48 AM
Berlinetta F1's Avatar
is just the rotor loose. or is the whole wheel loose
Old May 12, 2009 | 09:53 AM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
If you take off the tire, the rotor will be loose (assuming you dont have the center screws in). However, once you torque down the lug nuts holding the wheel - that will also hold the rotor tight. So a loose rotor is probably not your problem.
Inspect your ball joints - top/lower/and tie rod - or check your shock to see if the bottom clamp is still secure. You can also check under your car to see if something is loose under there.
Old May 13, 2009 | 06:03 AM
googoodc's Avatar
thanks man
sickofitall1113
Oct 10, 2006 09:39 PM
redryder
Sep 16, 2005 03:39 PM
tur3oDC4
Sep 16, 2005 11:26 AM
Hyb
11
Apr 2, 2005 08:14 AM
Regular Series
Aug 15, 2004 08:04 AM
