T4 Comp Turbo 67mm, Full Race Mani B-series, LOTS K20 parts
Parts for sale- I do not sell used and abused parts. Everything thing is either new or WORKS!
EXPENSIVE PARTS ON SALE!!! ANYTHING $350 and up is 15% off what I am asking...
NEW ATI Damper for Kseries still in box, never even mounted
Part# 918478, Race version, no belts included
$400 shipped- MARKDOWN TO $340 shipped....
K20a2 head. Installed Inline Pro springs and retainers. Comes with valve cover. Still on engine. Will pull off when paypal is received
$1100 shipped- MARKDOWN TO $935 shipped...
Bosch 1000cc injectors
Tuned a car then drove for 80 miles, so damn near brand new
Not enough for the power I am going for
Willing to trade for 1600cc injectors or enough cash to get me some 1600cc.
Comp Turbo 67mm turbo
T4, divided housing, .70ar exhaust housing, 4" inlet and 2.5" outlet
BRAND NEW and has Polished housing
Need a bigger turbo for my power, just got it last week for my stock k20a2 but I'm affraid it's too small for my k24!
$1000 shipped- MARKDOWN to $850 shipped
Fiberglass roof replacement for 92-95 civic hatchback.
Not using this, going with carbon fiber. It is a replacement roof, you have to cut your stock roof off and replace it with this one, it CAN NOT be used as just a roof cap.
$500 shipped
$500 shipped
Type S shifter box ONLY
$75 shipped
$75 shipped
PRB ecu out of 02-04 type S
$300 shipped
$300 shipped
02-04 Type S wiring harness
$250 shipped
$250 shipped
Stock Type S axles, 40k and perfect condition
$195 shipped
$195 shipped
Stock k20a2 water pump with 40k
$40 shipped
$40 shipped
k20a2 timing chain
$40 shipped
$40 shipped
k20a2 timing chain guides
$30 shipped
$30 shipped
k20a2 oil pump chain,gear,guide/tensioner
$100 shipped
$100 shipped
k20a2 stock head bolts
$19.99 shipped
$19.99 shipped
k20a2 oil pan standard or with -10an oil drain fitting
$125 shipped or $160 shipped
k20a2 stock pistons and rods with 80k
$75.25 shipped
k20a2 stock crank
$199.99 shipped
$75.25 shipped
k20a2 stock crank
$199.99 shipped
k20a2 timing chain cover
$49.69 shipped
$49.69 shipped
k20a2 windage tray
$40.01 shipped
$40.01 shipped
K20a2 water port on front of head
$30.01 shipped
$30.01 shipped
K20a2 thermostat and pipe
$74.99 shipped
$74.99 shipped
K20a2 coil packs
$59 shipped
$59 shipped
k20a2 engine mount
$20 shipped
$20 shipped
k20a2 injector cover
$45 shipped
$45 shipped
k20a2 stock fuel rail
$25 shipped
$25 shipped
30x12x3" Intercooler with 3" outlets
Core is 24x12x3"
Bar and plate, has spot where a wastegate was rubbing but it doesn't leak.
$125 shipped
Core is 24x12x3"
$125 shipped
B-series Full Race ramhorn
T4 and coated with the hot temp coating
bung for EGT welded on
$700 shipped
$700 shipped
B-series Skunk 2 adjustable cam gears
$150 shipped
$150 shipped
B-series obd2 alternator
$60 shipped
$60 shipped
LS AC compressor
$60 shipped
$60 shipped
3" AEM dryflow filter
$60 shipped
$60 shipped
Autometer Tach
$50 shipped
$50 shipped
NEW Animal House Racing vacuum block
$30 shipped
$30 shipped
SOLD
ARP Headstuds for K20a2
BNIB, never even opened
$133 shipped- SOLD
Competition Clutch stage 2 k-series
BNIB, bought it a while back for my all motor integra but sold it before i could install the clutch
$350 shipped- MARKDOWN TO $299.25 shipped SOLD
NEW K20a2 oil pump
$130 shipped- SOLD
K20a2 head. Still on block, perfect running condition
Can pull off if serious about buying
$700 shipped- SOLD and shipped out
K20a2 oil pump with 40k
$60 shipped- SOLD
K20a2 water block and tensioner (dont know what else to call it)
$50 shipped- SOLD
Stock 02-04 Type S throttle body w/sensors
$160 shipped- SOLD
K20a2 intermediate shaft
$125 shipped- SOLD
Wiseco pistons and Eagle rods
Assembled and balanced together
Never installed in engine
k20a2, 86mm, 9:1 compression
Just bought k24 built block so I no longer need these
$666 shipped- SOLD!!!
$133 shipped- SOLD
NEW K20a2 oil pump
$130 shipped- SOLD
$60 shipped- SOLD
$50 shipped- SOLD
$160 shipped- SOLD
$125 shipped- SOLD
Hawjap1gsr
Feb 3, 2012 11:44 AM
JDiMageDC2
Sep 25, 2003 02:36 PM
