Help!! Swappin my 00 civic
Old May 11, 2009 | 05:06 PM
WeAk_Cx's Avatar
Default Help!! Swappin my 00 civic
hey guys im swappin my 00 civic dx (used to have an LS) to a stock 96 dx sohc motor.. i am using a 99-00 dx harness which i plugged up everything except the o2 and intake air temp sensor.. i connected the orange wire from my iacv sensor straight to the ecu and the code for the iacv went away.. im using a p2t ecu because thats the only ecu i have for the moment. i started the car today and it kept on idling from 2000 rpm to 3000 rpm.. then as i give it a little gas, the motor will bog and die.. please if u can, help me out..
Old May 11, 2009 | 06:21 PM
WeAk_Cx's Avatar
Default Re: Help!! Swappin my 00 civic
somebody??
Old May 11, 2009 | 06:24 PM
prime-R's Avatar
check and see if the ecu ground is screwed on tight,last week when changing my engine harness i left it loose not know the car started but when i gave it gas it bogged and died it wont hurt trying.
Old May 11, 2009 | 06:34 PM
WeAk_Cx's Avatar
thanks i will do so first thing in the morning.. if anyone has any other advices please let me know.
Old May 11, 2009 | 06:39 PM
Former User's Avatar
Look for a disconnected vacuum hose and check the ignition timing with a timing gun.
Old May 11, 2009 | 06:56 PM
WeAk_Cx's Avatar
alright will do.. my throttle body is suckin in air like crazy.. that could be a problem.. thanks
Old May 12, 2009 | 11:06 AM
WeAk_Cx's Avatar
alright i've checked and theres no vacuum hoses unplugged.. the ground is good for the harness and theres nothing else i can think of.. it starts up fine but then it idles and everytime i step on the gas pedal, the motor will die.. i have one o2 thats not connected and the intake sensor isnt connected as well.. but i dont think that can be the problem... only codes that are comin out are those 2.. please help me find out whats wrong with my car..
Old May 12, 2009 | 12:03 PM
You should install and connect the IAT sensor.
Have you checked the ignition timing?
Old May 12, 2009 | 04:03 PM
WeAk_Cx's Avatar
yea i dont really know much about motors... can u send me a thread or something to do that?
Old May 13, 2009 | 06:49 AM
WeAk_Cx's Avatar
hold up thats the sensor that goes on the intake right?
Old May 13, 2009 | 07:15 AM
turbo_civicd16's Avatar
The car will run like extreme *** if you don't have the IAT sensor connected.
Old May 13, 2009 | 07:25 AM
WeAk_Cx's Avatar
alright thanks. i gotta find an intake for this thing lol..
Old May 14, 2009 | 06:41 AM
WeAk_Cx's Avatar
ok so im using a 99-00 dx harness with for a stock 96 dx motor.. there seems to only be one o2 sensor plug on the harness which is connected to the cat o2... does anybody know which pins i can just wire up the o2 sensor from the exhaust manifold directly to my ecu?? and my car keeps on idling frm 1000-2500 constantly.. when i gas it it bogs too..
Old May 15, 2009 | 05:19 AM
WeAk_Cx's Avatar
ttt need some adivices...
Old May 15, 2009 | 10:50 AM
WeAk_Cx's Avatar
how do i connect this sensor? theres no plug on my engine harness for the iac sensor.. the code 14 IAC (EACV) - idle air control valve..
bsublime44
15
Jul 10, 2017 02:32 AM
LiL JoN
12
Oct 6, 2011 05:10 PM
Trung Nguyen
14
Jul 19, 2011 02:11 PM
