Spun rod bearing! Now for a build. Would like to have some good input
So basically I spun a rod bearing in my built type R.
It is 12.5/1 compression right now with stock rods and acl bearings.
NoW I am going to just build the motor for turbo I think. Low compression build with H beam rods.
What I need to know from you guys is what's a good brand pistons and rods to go with.
The issue is I won't be going turbo for a while so I don't want to go too low compression and be slow as dogshit so I need insight on what would be a good starting point.
Thanks in advance
Thanks in advance
9:1 is just fine. if the car is NA, it WILL be slow. doesnt matter if its 9:1 or 12:1.
everyone has there own opinion on what pistons to run and probably rods. i like Endyn/Pauter combo, but its spendy and im sure your setup wont benefit from either. just get some Wiesco or CP pistons and Eagle rods.
good luck, post pics when done.
u_tal
Honda S2000
20
Sep 28, 2005 03:40 PM
highbrid
Jul 9, 2003 05:19 PM
