Viper 350HV and door actuators: all i need?
Would an alarm system, like the Viper 350HV and two door actuators be all i need to have keyless entry with an alarm?
This is the alarm i was looking at: http://cgi.ebay.com/NEW-DEI-Viper-35...3286.m20.l1116
Thanks
Thanks
I have the same question
I bough this door lock kit with micro switch. do I still need a relay?
http://www.infiniteelectronix.com/in...D&ProdID=12065
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Yes you would need to relays.
http://www.the12volt.com/doorlocks/page3.asp#arp
Use the reverse polarity for acurators
What is it exactly are you going to do with one 5wire actuator? 94
PS SPDT automotive relays can be found at any car audio/security shop or automotive supply store, even Radio Shack.
what about this? it saids come with 'door lock module' what exactly is a door lock module? Anything to do with the relays?? I am very confused!
http://www.amazon.com/Power-Door-Ply...2397603&sr=8-5
Just as stated, it is a control module, it controls the two actuators, it has the two relays for lock and unlock in it along with the circuit that is connected to the "micro switch" in one or both of the actuators, the system can be used as a stand alone central power door lock system or you can connect any alarm, remote start, alarm/remote start combo or key-less entry R/F unit to it for key-less entry operation. 94
hey guys i dont mean to thread jack but im lost with a problem that is completely associated with this topic. my door locks do not work, i have the same alarm as the OP and my remote is directly linked as the only way of unlocking and locking my doors, due to the mechanical locking bars being removed from inside the door preventing the door switch to work.
ive replaced the control module box in the d side door and checked for continuity which was okay. the fuse under the hood is fine, the sunroof still works. the inline fuses on the alarm are fine.
what else do i need to check that is preventing my locks from working? these relays? are there more actuators that may have failed.
candy eg
Audio / Security / Video
Dec 26, 2006 10:41 AM
T Rick
Oct 3, 2006 03:35 PM
