How to install asr subframe brace?
Old May 11, 2009 | 02:01 PM
amej8's Avatar
Default How to install asr subframe brace?
Just got my asr subframe brace for my 99 ex coupe in the mail today (that means it doesn't have the stock backing plates behind the subframe like the Si does). I went to look for a How-To but the only one I could find was the one on PW:JDM. But it can't be the right one because the subframe brace itself looks different from the pictures. And it doesn't say what to do with the other parts that I got along with the brace.
Here's what I got:
I think I have a rough idea on how to install it but I'm still confused as to use what bolts where.
Input?
Old May 11, 2009 | 07:13 PM
BlueIntegraBoy's Avatar
Default Re: How to install asr subframe brace?
http://www.passwordjdm.com/Install_N...R_Brace_EK.pdf
Old May 11, 2009 | 08:00 PM
k1llak973's Avatar
bump nice hardware
Old May 16, 2010 | 12:25 PM
NismoTyler's Avatar
Originally Posted by BlueIntegraBoy
Thanks for the link. My brace came with a sticker instead of instructions
Old May 16, 2010 | 12:36 PM
Ruben19's Avatar
my asr subframe is a bit different. i was able to use my stock lower control arm bolts.
i guess i have the new asr subframe design
Old May 16, 2010 | 05:01 PM
98civdx's Avatar
Master Detailer
The new designs allows you to use stock bolts
Old May 22, 2010 | 02:17 PM
NismoTyler's Avatar
stock bolts ftw!
Old May 22, 2010 | 06:26 PM
cvcrcr99's Avatar
Google.com would be a nice thing to use as well. This probably has been covered like 8,000 times.
Old May 22, 2010 | 08:01 PM
xero_xero's Avatar
bump for some clean hardware. can we get some comparison pics of the new and old design?
Old May 23, 2010 | 02:43 PM
NismoTyler's Avatar
New Design
Old May 23, 2010 | 02:45 PM
xero_xero's Avatar
props, what brand LCAs are those?
Old May 23, 2010 | 03:21 PM
NismoTyler's Avatar
pershiate it man the LCAs are Blox but the logo is so thin it didn't show up in the photos
Old May 23, 2010 | 05:31 PM
PSU's Avatar
PSU
formerly DxHatchback
Originally Posted by NismoTyler
stock bolts ftw!
Not necessarily.
Old May 23, 2010 | 05:59 PM
Vindicator9000's Avatar
318 Curves, 11 miles
The new style brace is different from the one in the instruction manual that was posted. The old style didn't have the L brackets, because the entire thing was cut out of one solid piece of aluminum. I imagine the new style is much cheaper and easier to produce, and would have less waste.
Basically, you use the hex bolts to attach the L-shaped pieces to the back of the brace.
Then, you remove the LCA bolts, line the brace up, and put the LCA bolts back in. Then line up the little backing plates and put the other bolts in. Keep in mind that they're different lengths... that tripped me up at first.
It's actually not a very difficult install, especially if you have an impact driver for the LCA bolts.
Please tell me you have a swaybar for this, and you're not just installing the brace by itself.
Old Jun 7, 2010 | 10:54 AM
kristo's Avatar
Loved
Bringing this up
This would refer to the 'first' brace (EK-RB-01 for EK), the commonly known model like OP has (EK-RB-02) also features separate L-brackets.
Was this new design announced somewhere? I surely missed it.
drmwgn
Honda Fit
Oct 20, 2007 09:09 PM
aznsins88
Mar 22, 2005 06:18 PM
ctownintegra
Suspension & Brakes
Feb 4, 2005 04:43 PM
ncVTEC1313
Nov 11, 2003 12:52 PM
AK94GSR
Feb 15, 2002 03:13 PM
