Suspension & Brakes Theory, alignment, spring rates....
car sits lower on one side
Old May 11, 2009 | 09:52 AM
Rtboy10's Avatar
Default car sits lower on one side
Hey guys I realized that my car sits lower on the driver side than it does on the passenger side. I can fit two fingers in between my passenger side front tire and fender but I cant on my driver side. It is noticeably different. I have rusted tokico blues and springs, could this be the problem. I have been told I cannot assume that it is a blown strut or bad springs. It seems like it is the same in the back of the car to lower on the driver side.
Old May 11, 2009 | 10:57 AM
TunerN00b's Avatar
Default Re: car sits lower on one side
Making an assumption here:
You have either a D or B series engine.
This makes the engine on the driver's side of the car. On a scale, I believe I ended up with a 55/45 weight distribution left/right in my GSR. The heavy side will always be lower, without setting uneven spring perch heights to compensate (which you lack).
Also, as cars age, they deform some. It could also be differences in the fenders. My car sits something like 1/2" height difference left/right (jack point measure), but the front fender gap is a larger difference (nearly 1"), so even though they look perfectly straight one of my fenders must be slightly off.
Old May 11, 2009 | 01:23 PM
Rtboy10's Avatar
I do not think that it is the weight distribution anyone else with some insight please.
Old May 11, 2009 | 02:18 PM
Chaveli's Avatar
From: Arlington/ South central LA, Texas/ Cali, USA
My ej2 sits the same way, Im a big guy though lol that could be the problem....I have Tokico blues and springs as well......
Old May 13, 2009 | 12:58 PM
vic479's Avatar
New User
does it affect your aligment. I'd like to know i have a similar situation.
Old May 13, 2009 | 06:21 PM
verycleanhatch's Avatar
when i had springs they were the same way on both of my hondas and i think my integra too.
pretty sure that it's uneven even with stock shocks and springs u just notice more when it's dropped.
Old May 14, 2009 | 06:43 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
LOL and why do you NOT think it's the weight distribution?
Let's see here.... engine is on the left side of the car... driver is on the left side of the car.... Those two things together can be over 600 pounds oriented towards the left side of the car. Did you really expect it to sit level?
If you're really concerned about it, you'll have to get something with adjustable-height spring perches so you can fine-tune the height so that the car sits level.
Old Aug 22, 2009 | 02:05 PM
t_mac's Avatar
my EL is doing this... its not because of the engine. there is a negligible difference in the cars very stance. Any help? I was doing work on the steering
Old Aug 22, 2009 | 02:53 PM
t_mac's Avatar
I got it figured out. It turns out that I had not re-installed the bracket that holds the stabilizer bar bushing? It's got 3 bolts and a hole and theres a little nipple it goes through when you fasten it down.
Old Aug 22, 2009 | 06:27 PM
coneking_cb7's Avatar
It's weight. When I set my car up for AX this year I got my ride height level from the "frame" to the ground. And I have a larger "finger" gap on one side than the other but it's level to the ground. My buddy always makes fun of me but I get even weight distribution this way so oh well.
Old Aug 22, 2009 | 07:16 PM
Egezzy's Avatar
Spongebrad Squarepants
then start checking for bent components or ripped/worn out bushings.
check psi in your tires. lol.
Old Aug 22, 2009 | 09:08 PM
honda-will's Avatar
ding ding ding .......we have a winner.
Old Aug 22, 2009 | 09:46 PM
ShinsenTuner's Avatar
No Jodas
guy... it's weight distribution from left to right in the car. The car itself is more driver justified weight wise due to the engine. The tranny sits on the passengar side which is lighter than the engine itself, which is on the driver side.
Old Aug 23, 2009 | 12:17 AM
boxeocampeon's Avatar
What kind of suspension are you running it could be your suspension is shot
Old Aug 24, 2009 | 08:01 PM
honda-will's Avatar
the engine does NOT weight much more than the tranny and battery weights combined. the difference is less than 20 pounds
Plus, b series axels are about the same length right? so everything inbetween them would be the middle right? now think about that.
Old Aug 24, 2009 | 08:58 PM
4doorDB7's Avatar
change the blues get koni yellows....way better
Old Aug 24, 2009 | 09:02 PM
Egezzy's Avatar
springs support the vehicles sprung weight. also you are stating the obvious.
Old Aug 25, 2009 | 02:50 AM
Tyson's Avatar
Uneven ride height is normal and expected. The smaller you close the overall gap, the easier it is to see the difference. It was uneven before.
Has to do with unevenly worn bushings, weight distribution with single driver and years of use.
Old Aug 25, 2009 | 02:52 AM
Paul-R's Avatar
How much do you weigh ?
i'm a fat guy so don't take this as an insult .
Old Aug 25, 2009 | 01:21 PM
TunerN00b's Avatar
Less than 20 lbs.? On scales, my DC2 ended up with a 55/45 left/right weight distribution. 5% is nearly 140 lbs., and we're talking a 10% difference here.
While B series axles are the same length (to reduce torque steer), the assumption that they're length has anything to do with engine/transmission placement is incorrect.
The axles are the same length due to an additional shaft (intermediate shaft) than transfers power to the driver's side, allowing the axle connected to it to be the same length as the passenger's side.
The transmission output is offset from the center by half the length of the intermediate shaft.
Old Aug 25, 2009 | 01:52 PM
Egezzy's Avatar
damn. tunern00b has got them glamour shots on lock. that intermediate shaft is looking sexy as **** with the white wall behind it!!
Old Aug 25, 2009 | 04:17 PM
TunerN00b's Avatar
We all have many photos readily available. Its called Google.
Ctrl-T (new tab)
tab (move from address bar to search bar)
"integra intermediate shaft"
click "images" in upper left
Less than 30 seconds total time. Took longer to type out the explanation, but I type slow for a programmer.
Anyway, back on topic...
Old Aug 25, 2009 | 06:17 PM
Egezzy's Avatar
Ctrl-T (new tab)
"jenna jameson"
fixed.
Old Aug 25, 2009 | 10:58 PM
honda-will's Avatar
Originally Posted by mister2racer
So I am sitting here tonight looking around HT and talking in PM to people about my built H22 I just posted into FI and Prelude... and I come across yet another B VS H arguement... and people start talking about all this weight BS again... the H series I hear rumours of anywhere from 85-125lb heavier then a B swap.
Here are some pics to let everyone with a B loose one of their points. (Not that I am against the B... the B is the ****... but I love the H as well and I have a H and I am tired of the weight argument)
I own a shop, and at the moment we are building several motors. So here I bring you some good ****.
All 3 Blocks are built with stock crank, forged rods, forged pistons, and iron sleeves done by benson (H22, D16) and darton (B16). I have a bensen'd B16 here as well but its already made the voyage to the engine stand so its not getting weighed. The only thing that is not fair in these pics is that the D has the oil pan on it... wasnt gonna take it off just for this BS.
H = 123lb short block
B = 104lb short block
D = 100lb short block + oil pan
So with totaly fair comparisons... the H is 19lb heavier in the short block.
NOW lets move on... the big word that I always hear is that its the H TRANS IS SOOOO HEAVY!!! Lets take a little peak here...
H trans = 96lb
B trans = 90lb
OK.. thats 6 lb... so we have a 25lb weight increase so far with the H22.
I will post here within a day or two as I weigh the assembled cylinder heads, as the H head is definatly heavier... but I would guess 10 lb heavier.
As for the rest of the crap... who cares. Intake manifolds are light for any motor and come in different flavors, same with headers and all that BS. Accessories are up to the owner of the car. Everything else hardly applies... flywheels are up to the user, axles, clutch, aluminum or steel oilpans, etc etc all this **** is up to the owner of the car so that crap doesnt need to be part of the comparison.
So what it comes down to is unless that H head is REALLY that much heavier... we are talking about
35 LB INCREASE!! Thats about how much weight off my *** I need to loose so I would be a hypocrite to be hard on the H.
OH YEA... you might want to see this yourself... here you go:
D16 Block:
B16 Block:
H22 Block:
B16 Trans:
H22 Trans:
-Charles
Modified by mister2racer at 3:48 AM 11/21/2003
Modified by mister2racer at 1:48 PM 5/2/2007
fryman
18
Oct 5, 2021 01:08 PM
dc4se
Apr 27, 2012 04:03 PM
Rtboy10
May 11, 2009 09:51 AM
Rtboy10
Apr 23, 2009 10:37 AM
