Tuning options for a 94 accord
A friend has a 94 accord ex. I am wondering what tuning options there are for him, Ideally we could just plug in a P28 ecu and tune away on that, but I don't know if that's the case and haven't had a chance to look at his ecu. what ecu does he have anyways?
I dont think the P0A is worth trying to mess with, from what I know unless you wanna try hex tuning it its not really supported any other way. Basically best choice is a ecu swap.
The P28 is a good option (as is the p72 if you are wanting to control secondaries of per say an h22 still), thats what I used for my boosted f22 (P28/ s300 hondata) and I could not be happier. Its a very simple swap of 2 wires (a6 and a11 pins), plug it into the harness, and start tuning.
So If he is running the F22b1 that doesnt have secondary runners, so a P28 should be just fine, i can chip it and tune int on crome np, and the pin switch, accords are the only ones you have to do that correct?
Yea its for a f22b1 it does not have secondaries and a p28 would be fine.
Pin swap the A6 and A11 pins on the accords harness, plug in your p28 (chipped), and your ready to start tuning.
leoverte
May 25, 2006 08:49 AM
