Need help picking coilovers/lca's
Hey guy's I have just started building the suspension on my 93eg si hatch. I have all new wheel bearings, omni power front camber kit, spc rear toe kit, sk2 rear camber kit. I just finished putting on new brembo brakes and steel braided lines with new hawk pads. The car has tokico blues with tokico springs they are really bad tons of surface rust and since my car sits lower on the driver side I am guessing a few struts are blown as well.
I will not be daily driving this car much, I will mostly be using it for track days and hopefully a few sessions. I was looking into getting PIC's but I was wondering if anyone had any suggestions as far as what to go with and what rates I should run. As far as LCA's I was thinking of going with some SRR's, with an asr rear sub-frame kit with 22mm sway.
Is there anything else that I would need I forgot to also add that I have a full energy susp bushing kit that I will be installing as well.
What would be causing my car to sit lower on on side than the other. What should I use other than poly bushing, should I just leave it stock.
ROK801
19
Sep 24, 2005 08:30 AM
91hondacrx
Oct 28, 2002 07:53 AM
