600cc+ OEM Injector?
Old May 11, 2009 | 08:24 AM
NirVTEC's Avatar
Default 600cc+ OEM Injector?
I know DSM has the 440/450s and Acura RDX 400(?) but is there a 600cc+ injector that will also work in a Honda out there?(Supra? RX7?)
I am switching to E85, and wanted to avoid the $3-400/set of RC/Precisions...
Old May 11, 2009 | 08:39 AM
NirVTEC's Avatar
Default Re: 600cc+ OEM Injector?
EVO 8 injectors were just mentioned to me.....
Does anyone know what has to be done to get them working on an OBD1 H22?
Old May 11, 2009 | 09:12 AM
1.5Slowmatic's Avatar
biggest ones i know of are from the gt500 they are 48lb/hrs or about 500ccs
Old May 11, 2009 | 09:23 AM
twkdCD595's Avatar
Bore the lower seals a little just like any other DSM injector. Your OBD1 clips will fit the injectors without problem. You already have a resistor box so you dont need to add one. Basically bore the seal, drop em in, and retune accordingly.
They are 560cc if I read the part number on them correctly.
Old May 11, 2009 | 09:25 AM
bigD's Avatar
evo injectors I believe are 560cc and will plug into a obd1 injector clip
Old May 11, 2009 | 09:26 AM
bigD's Avatar
beat me to it
Old May 11, 2009 | 09:32 AM
NirVTEC's Avatar
Thanks guy......Anxious to do the swap and tune with CORN!!!
Midwest E85 availability FTW!!!
Old May 11, 2009 | 09:41 AM
twkdCD595's Avatar
Originally Posted by bigD
beat me to it
OH and the part about the resistor box is because I think you have a prelude correct if I read the other post right?
Old May 11, 2009 | 10:16 AM
fastcody1's Avatar
the wife's srt-4 stage 2 injectors are 660's or 680's iirc
.adam.
Aug 16, 2006 11:16 AM
silverxcivic
Jan 29, 2006 05:38 PM
Panoply
Jul 19, 2005 01:37 PM
Panoply
Jul 18, 2005 09:36 AM
SOFLSOL
Jul 21, 2003 06:20 PM
