just swapped a motor need help
Old May 11, 2009 | 06:25 AM
JdmCrxKid's Avatar
Default just swapped a motor need help
And all my gears go in smooth except for 4th
Y is that???
Old May 11, 2009 | 06:26 AM
aptyk88's Avatar
Default Re: just swapped a motor
what linkage?
Old May 11, 2009 | 06:27 AM
redlinetuning's Avatar
Does 2nd or R go in smoothly? Did you fill your transmission with MTF? Does it grind?
Old May 11, 2009 | 06:38 AM
JdmCrxKid's Avatar
Stock linkage
Its a sohc zc and yes I put mtf in and 2nd and reverse goes in real smooth with no grinds
Old May 11, 2009 | 06:45 AM
JdmCrxKid's Avatar
When I shift to 4th it seems like its being blocked by a wall
its a cable tranny also
Old May 11, 2009 | 01:56 PM
JdmCrxKid's Avatar
Default Re: just swapped a motor need help
bump plz help
Old May 11, 2009 | 02:03 PM
spoonfedcrx's Avatar
Is this the trans that was in car? Like the problem occured after you swapped motor? Can you put it in 4th with the engine off?
Old May 11, 2009 | 02:23 PM
JdmCrxKid's Avatar
yes original tranny and it occured after the swap and i believe its the cable and it doesnt want to go into 4th while the car is off cant downshift on the freeway now
Old May 11, 2009 | 02:41 PM
johnnyonth3spot's Avatar
get a buddy to shift while you watch whats binding under your car
xTimmyx
Jul 9, 2010 11:45 AM
ej1 pilot
Apr 9, 2006 02:50 PM
jdmh22luda
Jul 15, 2005 05:47 AM
deagleEF8
Apr 26, 2004 08:19 PM
boomslang
Nov 18, 2001 12:00 AM
