Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Best front swaybar for eg
Old May 11, 2009 | 05:50 AM
captivahach's Avatar
Default Best front swaybar for eg
Planning on putting asr with there 24 mm rear what's a good front to go with that. Also my car is a dx do I need to do any mods to the front.
Old May 11, 2009 | 05:55 AM
pgpbubble's Avatar
Default Re: Best front swaybar for eg
Yes, EG EX/SI front LCAs or DC front LCAs
Old May 11, 2009 | 06:14 AM
Will ctr front lca arms work with the ctr sway bar
Old May 11, 2009 | 06:30 AM
lowside67's Avatar
I'm not sure if that combination will work. However, I am personally running the smallest swaybar I could get my hands on (EG SI) in the front paired with a 24mm ASR rear. I wanted a swaybar to help with feel at turn in but to not impair putting power down on the way out of the corner. My car is both an auto-x car and a track car that I run on square tires. Right now I have slightly higher rates in the front than rear with the rear bar at medium. I am going to go up in spring rate slightly in the rear for a square setup and tune with the bar from there.
Old May 11, 2009 | 07:36 AM
kommon_sense's Avatar
Was their a ctr from that era (92-95)? I know for sure that you can't run 96+ ctr arms.
Id suggest getting a set of integra/dc2 lower arms as you are guaranteed that they will have sway bar mounting holes. If you try to source eg/si lcas, someone may sell you the wrong ones.
I'd suggest replacing the bushings before installing them in your car.
As for swaybar size, the 22mm from the ex/si would be a good fit. I think its the smallest you can find. Unless you decide to spend $300 for the 18mm mugen bar.
Old May 11, 2009 | 09:52 AM
solo-x's Avatar
24mm ITR/GSR front bar.
Old May 11, 2009 | 10:07 AM
migs's Avatar
Just remove it all together. It will rotate much better.
Old May 11, 2009 | 11:07 AM
oinojo's Avatar
do not tune one end of the car to make the other end do what you want it to do.
EKDN
Dec 8, 2007 09:16 AM
VSMHatcH
Aug 29, 2004 10:52 AM
95dc2
Jan 12, 2004 11:19 AM
Mr. 1582
Jan 1, 2004 08:53 PM
HKxBlur
Feb 3, 2002 10:21 PM
