mount and linkage question
Old May 11, 2009 | 12:44 AM
EJ1_Sleeper's Avatar
Default mount and linkage question
Alright im getting ready to swap my LS in, and ive herd different things with mount manufactures. I have a set of Avid mounts i plan on running, and i also picked up a Hasport shift linkage. i just want to make sure that,
1) the mounts wont place the engine to far down = oil pan clearances
2) the shift linkage will work with the avid mounts placement?
i need to know before i go, swap it all in then get pissed that it doesnt fit right...
Old May 11, 2009 | 09:39 AM
big-guy 585's Avatar
Default Re: mount and linkage question
if u got the right mount u will be fine and shift linkage u can use out of a 90-91 intagra. u also have to knoch out the frame for the altnater to fit.
Old May 11, 2009 | 10:33 AM
mjfubar101's Avatar
Sounds like you should be ok to me. Although I have no experiance with Avid mounts but report back how it went
Old May 11, 2009 | 11:40 AM
crash232's Avatar
Well, for me I had to bend the front mount out of the way, take a mallet to where my alternator sits, and I ordered a custom shift linkage for swaps.. cant remember the website at the moment. Everything otherwise fits fine.
Old May 11, 2009 | 09:25 PM
guys...read the post. i already have the parts. im not running a hackjob linkage. i have a real deal HASPORT linkage and AVID mounts. i just wanted to make sure they both will work with each other. i know i have to cut the front bracket and bash the frame rail...
anyway talking with some friends it seems its going to work just fine. ill eventually have feedback when i get the swap in.
Old May 11, 2009 | 09:30 PM
frank_el_tanke's Avatar
it should work fine, friend has the same setup on his crx.
revikan
May 19, 2008 02:46 AM
killerpenguin21
Jun 1, 2007 08:12 PM
JohnnyM
Apr 27, 2004 02:22 PM
Fred n J_v2.0
Aug 27, 2003 05:10 PM
spettinger
Jul 1, 2002 05:05 PM
