Acrocat's For Sale Thread
I have a lot of stuff that is just sitting around. Time to get rid of a few things.
Spoon style mirrors. Power w/ blue tinted glass and no bases.
$40
Real Vision MC bases for 94-00 integra coupe.
$50
Stock USDM EG 2 door corners.
$10
Clear Amber EG 2 door corners
$20
Inner and outer tailight for EG hatch
$30
Clear Housing EG headlights
$80
Real JDM Integra SiR-G yellow fogs w/switch but no wiring or relay
$160
JDM Vti Cluster
$125
USDM CX Cluster
$30
52mm Blitz Boost Gauge
$70
Autometer water temp gauge. Just the gauge no sensor
$30
Autometer oil temp Gauge. Just the gauge no sending unit
$30
Urethane Type R Style Integra front lip.
$90
H&R springs integra/civic
$110
98 ITR subframe
$80
00 GSR shift linkage with prothane bushings and Real CTR shifter
$125
Buddy Blub Style FRP Rear bumper for 94-00 integra 2 door
$10
JDM ITR Hood. "Pending"
$60
00 USDM ITR Hatch Painted candy red with black trim
$100
GSR valve cover Shaved and painted Pewter metallic color
$110
GSR valve cover painted White with gold pearl
$80
00 GSR cams
$70
Cusco Catch Can Mint condition
$100
BDL Oil Cap
$30
BDL Cam Seal
$20
Brand New B Series Vtec ACL Rod Bearings
$60
Brand New b18a/b Main Bearings
$50
Brand New Eagle b18C Rod. Big bolt version
$70
~10' of -6an Summit Stainless line
$30
~11' of -3an Earls Teflon Braided line
$25
b18b1 cams
$20
GSR Fuel Rail
$20
obd2-b to obd1 Conversion harness
$70
Brand New Hondata s100
$150
Used USDM GSR pistons still in good shape
$60
RSR Ex Mag B Pipe 92-95 Civic hatch
$275
2.5" PWR Couplers and T bolt clamps
$10 per coupler and $4 per t bolt
Old school Omni power Rear LCA's. One is slightly bent on the end
$40
Rear Stainless brake lines for EG, EK, DC
$60
Civic Fuse box and dead pedal
$10 for the fuse box and $20 for the pedal
Front lower strut mounts
$40 for both
Not sure exactly what this mount is from
$5
Another engine bracket/mount i'm not sure about
$5
b16 oil pan. Had a oil drain line
$20
two CTR tranny/block Reinforcement brackets. Pretty hard to find
$80 each
one New slotted 4x100 11'' front rotor from fastbrakes.com
$20
ACT clutch for Hydro b series tranny
$80
A couple fuel filters and brackets
$10 each
Almost new Eg Si fuel filter and line
$15
pr3 power steering pump with AEM underdrive pulley
$60
p72 GSR power steering pump
$30
AC Compressor
$1
stock gsr shifter
$15
p30 flywheel
$25
$40
$50
$10
$20
$30
$80
$160
JDM Vti Cluster
$125
USDM CX Cluster
$30
$70
$30
$30
$90
$110
98 ITR subframe
$80
$125
$10
$60
$100
$110
$80
00 GSR cams
$70
$100
BDL Oil Cap
$30
BDL Cam Seal
$20
$60
$50
$70
$30
$25
b18b1 cams
$20
GSR Fuel Rail
$20
$70
$150
$60
$275
$40
$60
$40 for both
$5
$5
$20
$80 each
$20
$80
$10 each
$15
$60
$30
AC Compressor
$1
stock gsr shifter
$15
p30 flywheel
$25
the lower control arms are for 92-95 civics and 94-00 integra's. the one is bent though so i'm not sure how safe it would be to use unless it was fixed.
btcca4
Jun 19, 2005 10:27 PM
