92 accord f22a motor swap for f22b
Old May 10, 2009 | 05:21 PM
2.7V6's Avatar
Icon2 92 accord f22a motor swap for f22b
ok hey yall so I have 92 accord manual transmission with a f22a SOHC non-vtec and I'm wanting to put the f22b DOHC non-vtec in, I have the motor already and I am in the process of removing the f22a.
so when yall say dizzy, yall mean distributer right? and the h23 "dizzy" will be a sufficient match for the f22b? also I was told I will need to replace the intake manifold on the f22b with the f22a is this correct? and on the motor mount I saw on here that I will need to use the prelude mount not the accord is this correct?
anything else I need to be aware of please, please pass it on I will greatly appreciate any information
Old Sep 2, 2013 | 08:23 PM
backwood1's Avatar
Default Re: 92 accord f22a motor swap for f22b
I am doing a swap right now. An f22b2 for a f22a. It is a single cac for a single cam. What i found is the intake and exhaust manifolds are different. So use to manifolds that cam with the motor use bought. You also need to use the throttle body that comes with the new motor. The down pipe is also different. Use the mounts off the old motor. You may have to tap a couple of holes.
Old Sep 4, 2013 | 06:34 AM
2.7V6's Avatar
Wow talk about a blast from the past. Lol. I appreciate your input but the motor swap has been done for a couple years now. For the record the motor your talking about is not the same as I was referring to. The F22b I was installing is DOHC not single, it's a JDM motor from the Si prelude.
Brandon Rayner
Jun 4, 2016 05:15 PM
Oreo-TeCk
Oct 31, 2014 03:18 PM
Al-sonic
Jan 8, 2012 05:53 PM
ZCdohcHB
Nov 5, 2010 10:46 PM
