Brake light wont shut off
Old May 10, 2009 | 04:13 PM
BigAnteg's Avatar
Default Brake light wont shut off
my brake lights are on while the car is off
BigAnteg's Avatar
Default Re: Brake light wont shut off
how do i fix this problem Thanks
Old May 10, 2009 | 04:26 PM
BryanM.'s Avatar
Resident Gearhead
Brake light switch near the pedal may be stuck. Check it out.
Old May 10, 2009 | 04:50 PM
ONEsoda's Avatar
might be the cap on the brake master.
Old May 10, 2009 | 04:52 PM
BryanM.'s Avatar
Resident Gearhead
I think he is talking about the actual brake lights.
Old May 10, 2009 | 05:21 PM
Crx Jimmy's Avatar
replace the blue plastic/rubber **** that contacts the brake switch on the pedal, I bet there is broken blue plastic on the floor
Old May 10, 2009 | 05:23 PM
jdmprelude10's Avatar
New User
it may be your brake light switch
Old May 10, 2009 | 05:44 PM
BigAnteg's Avatar
thanks i found out what it was the switch needed to be adjusted the brake pedal wasnt pushing the brake switch in i apperciate everyone help
Old May 11, 2009 | 06:20 AM
barcafan_84's Avatar
wow i have a similar problem but its the hand brake or e-brake light that wont shut off event tho its not being used.
Old May 11, 2009 | 06:42 AM
Former User's Avatar
The brake fluid in the master cylinder reservoir may be low.
Old May 11, 2009 | 06:47 AM
nateb22's Avatar
before you go and dump some brake fluid in your master cylinder reservoir, look at the pads/rotors if they are worn out and trash, if so, you need new brakes, not brake fluid.
Old May 11, 2009 | 06:50 AM
Isn't it easier to first check the brake fluid level?
Old May 11, 2009 | 06:54 AM
92ehatch's Avatar
if your master cylinder is empty, and your pads are wore out completely then the problems is the pads.
once oyu install new pads and push the caliper pistons back in, the fluid will be full again.
thats why he stated to check the pads.
so here is what you do.
first check your brake pads, if they are not worn out then go on to fluid level
if your fluid level is low, fill it up.
if the fluid level is not low you might need a new brake fluid cap, with floating device.
Old May 11, 2009 | 07:00 AM
This is a good argument for checking the brake fluid level first.
Old May 11, 2009 | 07:07 AM
92ehatch's Avatar
yeah, but checking the pads first is a better idea because of safety.
that light wont hurt you, maybe your eyes.
if you just fill er up, and the problem is your pads are wore out (maybe the squealers broke off) then you have no brakes..
hmm that light might have been telling you something important
Old May 11, 2009 | 07:20 AM
From a troubleshooting standpoint, the first logical step to take when the brake light is ON is to check the brake fluid level. If the fluid is low, then I completely agree with both Nate and you that the brake pads, drums, and rotors should be inspected for wear. Looking for a leak in the hydraulic system should also be done.
If the brake fluid level is fine, however, completely different troubleshooting would be done, for example checking the fluid sensor in the reservoir cap and the parking brake and its switch.
This method of troubleshooting avoids unnecessary work.
Old May 11, 2009 | 01:37 PM
BryanM.'s Avatar
Resident Gearhead
Also, the float in the MC may be stuck down, causing the brake light to stay on. The hand brake switch my also be stuck, also causing the brake light to stay on.
Old May 20, 2009 | 04:45 PM
fallingup's Avatar
New User
I have a 2001 Civic LX and have figured out that my problem is the pad or **** that contacts the brake switch. Is it possible to get just that part or should I just buy and install a whole new switch? If it's possible to get just the plastic/rubber knobby thing, what's it called? I don't want to ask the guy at the auto parts store for the "plastic knobby thing"...haha
Thanks for helping!
Old May 21, 2009 | 05:37 AM
thanks to everybody, you were helpful as can be, the liquid was low but its true that the pads are the reason why its so low, i changed my pads and put more liquid and its fine now!
Old May 21, 2009 | 05:44 AM
hoangy's Avatar
Doh! I should've read through the whole thread first!
chugchuuug
Jan 28, 2018 12:07 PM
justBrowsing
Honda Civic (2001 - 2005)
Jun 27, 2014 12:26 PM
93grayeg
19
Sep 8, 2009 07:30 PM
kkwick
Apr 22, 2009 11:35 AM
84accord
Apr 1, 2006 12:16 AM
