mpfi conversion problemes!!!! intake mani sensor
hey im into doing dpfi to mpfi conversion ven i take a look at the back of my intake manifold and theres a sensor that i haent seen n other intake manifolds it looks to be a fast idle solenoid of some sort and it dosent plug into any of the engine harness plugs what is it and what can i do whit this???
i believe what you're looking at is the evap purge control solenoid valve. it helps gas vapors from escaping into the atmosphere. you can live without it, and i don't believe you will throw a code even if its not hooked up.
