Ls/Vtec swapped crx getting bad gas mileage...bogs around 3k rpm.
Old May 10, 2009 | 12:57 PM
Boosted_CRX_507's Avatar
Default Ls/Vtec swapped crx getting bad gas mileage...bogs around 3k rpm.
im getting around 200 miles to the tank and dont know what the problem is.
i got rid of all those purge solenoids on the firewall and now all i have is the map sensor
car pulls very hard WOT doesnt bog or anything, but when im just driving regular it starts to bog/hesitate around 3k rpm.
It also idles higher then normal, like around 1500, i just slightly tap the gas and goes back down to around 800.
could it be my IACV starting to go bad? i checked my vaccum lines their all good.
as far as the gas mileage and the bogging, could that be the o2 sensors? im running a PR3 B16 ecu.
any help is greatly appreciated.
Old May 10, 2009 | 02:12 PM
KARSON's Avatar
Default Re: Ls/Vtec swapped crx getting bad gas mileage...bogs around 3k rpm.
switch around your fuel injectors.
Old May 10, 2009 | 02:59 PM
think they could be bad? i was thinking it could be my spark plug wires, havnet replaced them, they got about 56k miles on them.
Old May 13, 2009 | 07:21 PM
anyone had/have a problem like this?
car sputters every once in a while, doesnt do it if im at WOT.
and gas mileage sucks...o2 sensors? will that cause the car to sputter?
Old May 13, 2009 | 07:27 PM
88Hatchy's Avatar
Is this city mileage? If it is, I wouldn't worry about it. I only get about 20 mpg in the city also. You didn't say anything about being tuned. You are tuned, aren't you?
Old May 14, 2009 | 07:30 PM
i am untuned, running an OBD0 b16 ecu (PR3) stock ls pistons...
its gotta be something with my o2 sensors, i have both of them plugged in, thats when it bogs, if i unplug both of them, or just the 2nd one it wont bog, but still get the same gas mileage, like around 15mpg
every once in a while i get a check engine light too, never checked to see wat code it is, cause all i do is turn the car off and turn it back on and it resets
i only get that like once every other week
Old May 14, 2009 | 08:52 PM
88Hatchy's Avatar
Check the CEL, address the issue(s). Get some cam gears, adjust them. Then get it tuned
BTW, how are you getting 200 miles to a tank @ 15 mpg?
Old May 16, 2009 | 06:27 AM
aight, i will check the CEL...and i never calculated how many mpg i get, i just know i get around 200-250 to the tank
i think i might just convert to obd1 see if that fixes anything.
neozero999
12
Aug 18, 2016 06:48 PM
usdm07
Feb 9, 2010 02:31 PM
z6hatchboy
Mar 27, 2008 09:42 AM
XxJDMugenCivicxX
29
Feb 14, 2007 06:25 PM
nver2
Feb 3, 2004 01:27 PM
