How To - Replace Glass Sunroof
Old May 10, 2009 | 10:48 AM
Spoon Sports's Avatar
Suit up
Default How To - Replace Glass Sunroof
This thread will cover on how to replace a glass sunroof on a 1989 Honda Civic Si hatchback
Tools you will need:
- A philips screwdriver
- A size 10 wrench
- Flathead screw driver
Make sure that your sunroof is closed tight and pull back the sunroof cover the exposes your glass sunroof
My glass sunroof is cracked and it annoys me!
Looking up at the glass sunroof you will see on each side their seems to be railing covers. On each railing cover their is a marble size cover that hides the screw. Pop them off.
Once popped off, unscrew both from each side.
Once unscrewed, slide back gently on the railing cover.
Once the railing cover is off, you will see their are 4 nuts on each side (Total of 8).
Unbolt all 8 with your size 10 wrench.
Once you have unbolted all 8 nuts, go ahead and push up on the glass and shimmy it out. Once all 8 studs from the glass sunroof are off the hinges pull the glass out gently.
Sunroof glass is out
Grab your new sunroof glass, pop it back in gently and matching the hinges and repeat the steps backwards
Their you have it, you now have replaced your glass sunroof. Enjoy and hopefully this write up helps out confused owners.
spoolinvtec54
Jul 5, 2011 05:31 PM
jbell
Honda S2000
16
Sep 18, 2008 06:26 PM
ziptie
Jul 15, 2007 03:33 PM
codenamezero
Feb 10, 2007 09:00 AM
dLo GSR-stolen-now-WRX
Nov 6, 2002 12:41 PM
