Technical question----Charcoal canister/vacuum line relocation
Old May 10, 2009 | 10:37 AM
YOUR MOM's Avatar
Default Technical question----Charcoal canister/vacuum line relocation
Ok so I have an 89 CRX Si with a b16 swap. The JDM OBD0 motor. I am currently running the charcoal canister and sensors on the firewall. However, I have a skunk2 TB which allows me to have the MAF sensor on the TB. I purchased the sensor and installed it with a new O-ring. I havent switched out anything yet but what else would I need to do to completely eliminate the whole assembly on the firewall???
Any help would be greatly appreciated!
Old May 10, 2009 | 10:58 AM
8dxhatchy8's Avatar
Default Re: Technical question----Charcoal canister/vacuum line relocation
not sure if u cant run it without the canister or not, i just tucked it under my intake mani, as for the map sensor just plug it into the TB and u can toss the firewall one out...
Old May 10, 2009 | 05:06 PM
Crx Jimmy's Avatar
just extend the wires so the plug reaches the throttle body mounted map, and you can ditch all the firewall stuff, it wont throw any code
Old May 10, 2009 | 05:54 PM
YOUR MOM's Avatar
Yeah but how would I run the vacuum lines?
Old May 10, 2009 | 09:10 PM
8dxhatchy8's Avatar
the setup on the firewall is two pieces, ones the map and the other is for the canister, not sure what its called but it seperates from the map...
chris3385
Jan 3, 2009 04:49 AM
143MYVTECEF
14
Dec 1, 2006 08:12 PM
90b20vteckidd
17
Sep 27, 2006 06:03 PM
vtecn8ive
Jun 19, 2005 12:10 PM
Ri5e
Mar 27, 2003 06:18 PM
