d15b7 bottom with zc head help
Old May 10, 2009 | 10:03 AM
mayfly's Avatar
Default d15b7 bottom with zc head help
i have a d15b7 bottom and a sohc zc head that i want to put on for more aggressive acceleration. if anyone has some insight if this is a good build or will bolt up fine please let me know, also what head gasket should i use? etc etc anyone got an idea?
Old May 10, 2009 | 06:47 PM
mayfly's Avatar
Default Re: d15b7 bottom with zc head help
bump for help. please guys
Old May 10, 2009 | 07:25 PM
~sp33~'s Avatar
EFB055
What ZC?
Just use a shorter ratio transmission.
Old May 10, 2009 | 09:17 PM
mayfly's Avatar
its a SOHC zc head obd0 with a d15b7 bottom block. so my question is, will it work?
Old May 11, 2009 | 01:39 PM
24TEN's Avatar
PHANTOM MENACE
It'll work. It's basically just going to be like running a stock engine with a tiny bit more kick. If your car is still DPFI, then yeah you'll feel a difference. If it's already MPFI then it's not going to be anything drastic (if at all). As stated, a shorter geared tranny would probably make a bigger impact.
As for the head gasket, it's basically still going to be stock so use a normal head gasket (B2/B7/A6, etc). You can also use the Z6 head gasket which is actually cheaper at the dealer and is metal, but you have to make sure both the head and block are straight and within spec.
Old May 11, 2009 | 01:47 PM
von1988's Avatar
New User
It should work. I would convert it to MPFI first. On my old engine i had an A6 with a zc cam and that thing was a mean mother.
Old May 11, 2009 | 05:01 PM
mayfly's Avatar
ok sweet. thanks guys. so i have another question, what would be a nice daily driver drop height for a civic hatch, im currently slammed but i want to raise it, so what would be a decent daily driver height?
Old May 11, 2009 | 07:35 PM
~sp33~'s Avatar
EFB055
That's fairly subjective. High enough to get over speed humps is a good measurement.
Old May 18, 2009 | 07:39 PM
1turbodeg's Avatar
get a exospeed stage 3 cam...bisimoto valve springs....pm6 pistons.....you would have a good lil daily driver revin up 9k all day no problem.....
chris riz
12
Sep 22, 2011 12:34 PM
1phatEG8
May 11, 2009 02:12 PM
boosted 95 coupe
Jun 12, 2007 10:07 AM
blackEF
Oct 30, 2002 04:33 AM
