my crx is pissed at me
i have a 91 crx hf that got wrecked 2 years sgo and at the time the engine ran fine.but i finally got around 2 fixing it and now it won't start.it will turn over but won't run.i figured the new plugs and wires since it was left outside w/out a hood on it. but the new plugs and wires didn't help. i took one of the wires loose w/a plug on the end of it and tried to start it 2 c if there was any spark on the end but there was nothing. maybe i need a coil or a rotor button and distributer cap or maybe a whole distributor. or maybe it something alltogther else im missing? need help with it
i'd try to replace the cap and rotor, and you could test the coil with a voltage meter i think the coil should have about 8-10 ohms of resistans, but search to make sure i'm correct on that, it been a while since i have had this problem
check the cables that connect the distributor to the power if that makes any sense. i unplug the distributor on purpose and call my work and tell them my car doesnt work and i let them here the car turn over but not start hahaha funny **** =]. u might have ripped a wire off or something. make sure its call connected
If it helps. I left my hood off and it rained(for like 3 months) and i needed to replace my distributor..im almost certain that is it.
try to find someone to use theirs first then buy a new one if you need it
Here are some links on how to test your fuel pump and fuel pressure regulator, main relay and so on. It sounds to me like the fuse for your fuel pump is blown. Or the fuel is just not making it to the engine.
http://media.honda.co.uk/car/owner/media/manuals/CRXManual/62SH200/6-76.pdf
http://media.honda.co.uk/car/owner/media/manuals/CRXManual/62SH200/6-78.pdf
If you are trying to start it using the gas that has been sitting for three years, that is at least part of your problem.
Your main relay can fail while sitting as well, but if all fuses etc. check out your distributor, it might be toast.
get spark first.....if you have a can of brake clean laying around you can shoot some in the intake and see if it trys to run...if it does then troubleshoot the fuel system, but you need to have spark first off.
You left it out fron ur house with out a hood for 2 years? i dont know about any one else but if i drove by and saw something i needed and i saw ur car id take it.
micah13x
11
Apr 14, 2011 03:09 PM
Coltmorris
Jul 13, 2009 11:32 AM
killercrx91
Sep 28, 2008 04:03 PM
