Is rsx springs similiar to ep3
Will a 02' rsx tein s-tech lowering springs fit my 02' 4lug ep3??
Help me out ..... Thanks for the replies
So Mustclime you are saying that you can use the springs of a Type-S (or any other such as the Teins that were made for the Type-S) no problems what so ever? Just want to clarify...
did a search on this forum:
https://honda-tech.com/forums/showpo...72&postcount=6
i'm lucky, i just need new tie rods
Why is he stupid for??? Because he actually asked a tech related question instead of the what suspension should I put or which do you think looks nicer questions?
And before calling out some one stupid you should learn to write properly cause really all you are doing making yourself sound stupid!
The spring is similiar between 02-04 RSX and the EP3, however, it is different from the 05-06 RSX. If you are swapping these two with each other, EP3 has a lower drop vs rsx. I dont know why you would do this but if you do, good luck
