no start, wiring possibly?
Old May 10, 2009 | 09:17 AM
ryanevansoh's Avatar
Default no start, wiring possibly?
ok well im trying to start my hatch with a b18a1 out of a 90 teg. well i know its getting fuel, it has good compression, timing is right, but no spark. im wondering if it was my wiring that i did for the mpfi. well here is a diagram of what my wiring to the dizzy looks like. i think that the ones i said are "tan" might actually be a faded orange or white. any suggestions help
Old May 10, 2009 | 09:59 AM
Default Re: no start, wiring possibly?
anybody?
Old May 10, 2009 | 07:10 PM
bump
Old May 10, 2009 | 08:02 PM
bump, help needed!
Old May 10, 2009 | 09:17 PM
come on guys!!! really lost
Old May 11, 2009 | 10:08 AM
big-guy 585's Avatar
well if u did the swap and has a sohc system, then ur going to have to set it up for dohc system. the 2 wires on the dizzy ur going to have to cut and re wire it to the ecu is a blue with yellow stripe, and a blue with green strip on the dizzy on the bigger plug. now for the ecu u have 2 black plugs that go in the ecu? if so the smaller on of the 2. there numbers on it u have to cut number #2 wire and #29(easyer way to explain it is if u have the thos plugs pluged into the ecu it the frist to next to the bigger plug. iam not sure which wire gose were u will have to play around with it lol but make sure u cut the wire so u have room to play with.
Old May 11, 2009 | 12:16 PM
hellraiser7492's Avatar
Agreed! Good luck
Old May 11, 2009 | 12:50 PM
so for the mpfi on a b18a its different then for a sohc?
Old May 12, 2009 | 08:11 PM
yea u got to rewire the injectors give me untill the end of the week and ill have i diagram for u. u have the egine harness for acura or of ur hatch ? idk if there a diffrenets. but every thing lines up harness wise. egine to main?
Old May 12, 2009 | 08:53 PM
hasty91ef's Avatar
Do you have the right ecu?
Old May 13, 2009 | 08:28 AM
sh!ft's Avatar
Who the fack changed my title?!
check rywire.com or just put your plug back to stock if you can remember the wire pattern and get a conversion harness off egay
Old May 13, 2009 | 10:44 AM
mitsubishiv5's Avatar
i just found out that the actualy guy ryan from rywire lives around me, weird :D
Old May 13, 2009 | 01:17 PM
TeamRedline89Hatch's Avatar
I'm having the same problem with my STD to Si MPFI. Good luck man.
Old May 13, 2009 | 01:20 PM
sh!ft's Avatar
cool!
Old May 18, 2009 | 01:23 PM
ok well i tried switching out the coil pack for a one that guaranteed working condition. still no luck, so im convinced its the wiring. can anyone tell me what wires go to where? cuz im lost and need this running!
bmiller17
Feb 2, 2006 05:42 AM
hotinteggy
Mar 13, 2005 09:36 AM
Garcia-Racing
Oct 4, 2004 07:08 PM
