Tuning all motor Probkems
Old May 10, 2009 | 08:14 AM
H22hatchin's Avatar
Default Tuning all motor Probkems
i helped put together a motor for my buddy and yesterday we went to the dyno for the first time and had Ron at Rs tune it(reputable tuner), motor doesnt make any power like it should.
145hp and 120ftlb and it hits these numbers by 5k on the dyno VTEC DOESN'T ADD ANY HORSE POWER WHEN IT HITS! thats whats weird to me, Vtec is really loud when it hits but does not add any power sometimes drops during vtec. we spend probably 4 hrs on the dyno trying to figure it out. motor runs perfect. compression is 230 across, motors turns over easy. Maybe something wrong with my set up? are these cams okay with the 13.1 compression this motor has? Right now cams are both set at 0degres and timing is dead on. Thanks guys for any help. okay heres the setup,
Tuned on e85 with 750cc injecotrs
bottom end
GSR block
LS crank
Ls Rods
CTR pistons
completley Balanced
Arp Rod Bolts
Head
Gsr Head no porting
Jun3 Cams
BC retainers and Dual Valvesprings
SuperTech Std. valves
Cometic Head gasket
Skunk2 intake mani
68mm throttle body
Tri y replica header
2.5 exhaust
Old May 10, 2009 | 08:28 AM
inspector01's Avatar
Default Re: Tuning all motor Probkems
What EMS?? Is vtec engaging for sure?? Im gonna say no, it sounds exactly like that, but Ron would have known that for sure. Otherwise are you positive that your cam timing is correct?? I would assume you would have checked that too.
Old May 10, 2009 | 08:59 AM
H22hatchin's Avatar
using chrome. and vtec is defineatly engaging. i mean when it pops off its crazy loud on the dyno but it just is not doing anything. and cams are set at 0 degrees for sure. should i try to advance them or?? thanks for the reply man
Old May 10, 2009 | 09:07 AM
I dont do much with all motor, but im sure the cams need to be messed with some, but they should still make some power at 0,0. It really sounds like vtec isn't engaging if it makes peak power at 5k and it is dropping power in vtec.
Old May 11, 2009 | 03:07 PM
postman's Avatar
post a graph of the current dyno run, your fuel and timing maps and crossover point for vtec. might help some maybe
Old May 11, 2009 | 06:19 PM
pgpbubble's Avatar
x2. what are the timing maps?
Old May 11, 2009 | 06:51 PM
93turbo16's Avatar
Compression seems kind of low for that kind of claimed compression. Did you do it WOT?
I would try doing a leakdown test if you have one available.
Old May 11, 2009 | 06:59 PM
H22hatchin's Avatar
i messed with cam timing at home and it made a hell of a diffrence so i will be going back to dyno again thanks guys
Old May 14, 2009 | 06:38 AM
sander's Avatar
2.7(p/t)
Did you check your base timing?
lriver0001
Apr 13, 2011 09:20 PM
H22hatchin
May 13, 2009 08:28 PM
integranator
Dec 17, 2007 10:37 PM
CompressionFed
47
Dec 29, 2006 10:08 AM
b19coupe
26
Oct 15, 2004 08:44 PM
