Acura Integra GSR B18C1 part out OBD1 2 door +many others
I am parting out a 1995 Acura Integra GSR B18C1
I am parting out everything! No reasonable offer refused!
Best way to contact is SMS (216) 374-7985 Myron.
-B18C1 Sleeved 85.1mm block that needs to be bored out to 85.5mm, great for all motor set up. I am going turbo, the head gasket will not hold under boost, but NA would be awesome! Very strong block. $600.
-B18C1/5 Eagle rods, brand new in the box, never been used, $300
-B16A block from Japan, 40000 miles, currently disassembled $250
-94-01 Integra 2 door rear hatch with tinted glass, spoiler, painted Ferrari red, no wiring. Shaved emblem holes except for the "A" emblem. Clean, no rust. $50
-5spd hydro conversion, all pedals, sensors, master cylinder $50
-HKS Super Dragger cat back exaust for 2 door DC2 $300
-94-01 Integra fuel door (have 2) in Milano red $10
-94-97 Integra rear 2 door rear bumper cover black, scuffed, $50
-97+ Integra 2 door rear bumper cover, needs work, milano red $50
-94-01 Integra 2 door rear tail lights, amber turn signals. $40 set
-90-93 Integra 2 door rear tail lights $40
-90-93 Integra almoast complete AC system $ offers
-90-93 Integra front seat belt tracks $40 set, $25 each
-Stereo installation speaker wire for subs, have a bunch.
-94-01 Integra front ABS sensors, removed in working condition. $15 each
-90-93 Integra B18A1 power steering pump, 19xxx miles! $40
-94-97 Integra steering column with key and ignition switch. $40
-B18C1 bottom timing gear $10
-GSR buffle plate $?
-94 and up trans mount, 5spd. $20
-94-01 Integra 2 door exaust, complete, almoast new, includes OBD2 converter with 2 O2 sensors in working condition $120
-94-01 Integra GSR and others converter, OBD1 (1 O2 sensor) $50
-90-93 Integra B16 LSD cable trans Perfect condition $700
-3.0L engine, V6, from 2002 Accord, has under 5000 miles, been in heated storage for 7 years. $500
-Universal intercooler, good for up to 300hp, 2" by 6" by 30". $70
-Integra 94+ fender to bumper brackets $15 for a set
-B18 B16 Vtec spartk plug cOEM over $20
You can call or text me at REASONABLE hours (216) 374 7985 Myron.
I do not answer blocked calls.
Some low balling will be allowed, but extreme low ballers will be kicked in the head
B18C1 GSR head, (includes cams, cam caps, solenoid, sensors) $350
P72 ECU, virgin, never messed with $old
94+ Integra midshaft $40
94+ Integra passenger axle $30
90-93 Integra front camber kit, no name, brand new. Includes polyurethane inserts. $40
B16 Eagle rods, used, $old
B16 CP pistons Sold
GSR hydro trans, no grinds, 99628 miles $500
shifter lingage from GSR $50
shifter linkage from B16A no shifter lever $40
OBD1 GSR wiring harness $150
LS cable trans from 91 Integra, 79xxx miles no grinds $350
XTD stage 2 clutch for 90-91 Ls cable trans, brand new in the box $100
Ingen CAI for GSR $100
B16 CP pistons Sold
