SPEEDOMETER wont work ? re-set ?
ok, on my 96 civc the speedometer doesnt always work, if i un-clip the switch on the tranny speed sensor and clip it back on it works for 1 mile then starts to hop and turns off ??
what are the possibole reasons for this ?
I had a similar experience when I installed an aftermarket cruise control in my Civic VX just weeks before my first cross-country trip. I clipped onto the speed sensor line but the cruise wouldn't engage. Then I noticed the speedometer stopped working. I eventually used the magnetic sensor with the cruise (and later the tach sensor because the shop that replaced the axles left it on the old half-axle).
Anyway, getting to the point, the speedometer worked for a little bit then stopped completely. I also got a check engine light. A trip to the shop and $400 later and I had a new speed sensor. Apparently they eventually die -- mine made it to 110,000 miles or so. I gather it isn't all that difficult to replace but I didn't happen to have the right tools to get it out (I assumed all I'd need would be a deep-well socket of the right size, but if I remember right, it was locked in there tight and the last thing I needed was to strip threads or break the sensor in half.)
I'd start there: diagnosing the speed sensor.
Renhard
Sep 11, 2018 08:31 AM
Freckles
Aug 20, 2012 10:30 PM
