Can I mix my green oem coolant with the new blue Type 2 coolant.
He's correct yes you can mix the new blue with your old green. We do it all the time at Honda. On my own personal car I drain the radiator and the block than fill my whole system with the blue coolant. That's just me tho.
this is wrong. You can mix IOAT (red,gm-yellow,ford-blue,honda-etc) and OAT (green) coolant. Once you do that though you have to start following the service schedule for the oat (green) coolant. which is about every 2 years. The difference in the coolants is the additives they have in them. The extended mile stuff uses InOrganic Additives which last longer, while the green stuff has organic additives which doesnt last as long.
Check out page 2 of this article published by honda. http://www.in.acura.com/Rjanisis/pubs/SN/A950500.PDF
well, i dont know what chem. reactions happen when mixing dexcool and the reg. ****, but i can say i have personally seen a toyota with 9,000mi. on it completely ruin a longblock (head and block warped due to overheating) from being filled with dexcool. no sludege, just f*ked...take it or leave it.
why did they have to add coolant to a vehicle with 9000 miles? exactly, something caused the coolant to be low, customer overheated it, then added coolant to the already damaged engine. your dealership was looking for a way to avoid paying for an engine. You are wrong. dexcool will not cause any chemical reaction that will cause a toyota to overheat, something else did
Hey guys, apologies for restarting an old thread. But I am trying to get a definitive answer to my question below:
My Accord 2006 (4Cyl) was due for an Oil change. Took it to the local shop (Car-X) and got the oil changed. The car previously had the Blue coolant (guessing Type 2). Since it was low, the shop topped it off with Green coolant from Valvoline.
Will this harm my engine/coolant system? If so, should I get my radiator flushed and replace with all new Honda Type 2? Approximately how much does that cost?
Thank you!
Thank you!
Thank you!
Thank you!
Ignore everything srmofo has said. It is pure ignorance.....
Thank you so much DCFIVER! I appreciate the reply.
Considering that the Valvoline Green may not be compatible with the Honda Blue, I am planning to get a Coolant flush with the Honda Type 2 Coolant. I guess that should resolve things. So I'm out a $100 then
I HAVE ALWAYS READ ON EVERY NEW RADIATOR I HAVE SEEN A LITTLE SIGN STATING "AVOID MIXING OF COOLANT" OR SOMETHING LIKE THAT MY ADVICE DRAIN AND REFILL ITS NOT THAT HARD JUST BE SURE TO LEAVE VALVE OPEN THAT IS USED TO LET AIR ESCAPE DON'T LET ANY AIR REMAIN IN LINES
You should only add the same coolant you have in the car. Red/orange definitely don't use because those are specifically for some European cars. Now if you wanted to change it to blue then empty it, cycle some plain water through it to wash it out and add blue. Mixing can occasionally cause the coolant to clog up.
Paprika
Jun 13, 2022 05:32 PM
OldMrAccord
Nov 24, 2010 07:40 PM
2000civicsilver
Jul 28, 2008 08:46 PM
silvercivicsir
10
Sep 18, 2005 11:20 AM
