Clearance issues with twin disc?
So I installed a twin disc in my YS1 trans, ordered it for a cable trans, and the pressure plate is rubbing on the bolt that holds the throw out fork onto the clutch arm shaft. Anyone else ever have this problem?? It's the oem bolt, I used their throw out bearing. Also the throw out bearing provided rides the diaphram on the inner sleeve, instead of the bearing portion of the throw out. Any insight?
aluminum ring is where the bolt is hitting
The bolt, and some shavings
hmmmm. i used a hydro exedy twin disk with my ys1, and IF i remember right, i just used a throw out bearing for a ys1 tranny. never had any clearance issues.
bump for pics added
Hmm, I have a CM twin in my cable tranny. I don't think it's touching but I'm curious now. I'm going to be pulling the current tranny in a couple days for a GSR YS1, so I'll know then.
Yeah, you can just trim that bolt or find one with a button head. The plastic on the throwout bearing should have been trimmed. If it was not, you can grind it off yourself.
thanks, im still going to call comp tomorrow. I was thinking about trimming the plastic back, and milling down the bolt head, as well as a little bit on the fork to recess the bolt head down a little more?
awesome, thanks for the input. I was stoked to fire off the new build
, then devestated to see aluminum shavings flying from my bell housing
dascivic96
Transmission & Drivetrain
37
May 7, 2012 03:36 PM
beanbag
57
Mar 19, 2009 12:12 PM
V-SPEC 1
May 19, 2007 07:45 PM
Chiovnidca
Jun 11, 2004 07:59 PM
