Suspension & Brakes Theory, alignment, spring rates....
what kind of rotors are you guys runnin?
Old May 9, 2009 | 02:58 PM
pjr710's Avatar
Default what kind of rotors are you guys runnin?
i think mine are warped because i'm gettin a shake in the pedal at high speeds. i was looking at just blank brembos for like $90 just because of the name. i was just wondering what everyone else is runnin on and how theyre doin
Old May 9, 2009 | 05:45 PM
racebum's Avatar
Default Re: what kind of rotors are you guys runnin?
some cheap things that came in a plain white box. rotors are disposable, the pads are where you should spend money. get any cheap rotor coupled with the best pad you can afford.
Old May 9, 2009 | 07:16 PM
builthatch's Avatar
MiG-21 superfan
there are a ton of differences between a high quality rotor, like an OEM brembo rotor, and some centric or mass retailer private label chinese/taiwanese rotor.
metallurgy is the one that most people don't think of. there is a ton of science behind it and you can read all you want on google about it as there are a ton of articles and research on the subject, but one thing you get with a brand like brembo is consistency. each rotor will have the same properties and tolerance as the next. a centric rotor might have balance issues, most likely does have issues with its composition.....but it will 'work'
chinese rotors have their place and there is a huge market for them, but for a performance application i would never skimp on brakes. personally, i'd never skimp on brakes no matter what vehicle, but there is something to be said regarding the quality of a brand like brembo and how it can give you peace of mind with something so important to safety like braking.
same reason i don't ever run knock off wheels...it's just not worth negligible savings considering how important the part is to safety.
i agree that pads are very important, but in the same way that i believe good rotors are important because i just dont mess around/skimp with important elements of my car like brakes.
Old May 9, 2009 | 08:08 PM
pjr710's Avatar
so is the brembo a good choice? would they be better than goin oem honda?
Old May 9, 2009 | 08:17 PM
builthatch's Avatar
MiG-21 superfan
either/or...both are solid choices.
OEM is going to be a very high quality rotor, and brembo will meet or exceed those tolerances and specifications. at that point, i'd weight the cost differences.
your typical OE honda front rotor pair will be in the 100 dollar range (list-25% pricing)
i am unaware of how much brembo full face rotors are but i see you mentioned 90 dollars
Old May 9, 2009 | 09:27 PM
pjr710's Avatar
yea, i think a dealer on here is sellin for 90 .. i think i paid like 120 for my honda rotors like 2 years ago... but i guess theyre shot now ... im thinking from auto xing
acchaser
Sep 25, 2006 08:06 PM
90AcuraIntegra04
Nov 8, 2005 02:42 PM
Bbasso
Jul 31, 2004 06:49 AM
n00b
Jul 27, 2004 07:01 AM
tmekjian
May 10, 2003 04:04 PM
